If you can source an eclipse or similar small tap holder then an easy way to get round the need for a centre is to grind a small flat on the side of the tap for the holder to key against – I do this by using the corner of the wheel on an off hand grinder. The tap itself is held loosely in the drill chuck to act as a guide as here – works very well and efficiently – two handed drive.
All the 8BA threads on the two cylinder blocks for this corliss engine was done as such using just the one tap.
If you can't source a small holder then a thin disc, knurled on the periphery with a grub screw through to key the tap is also very efficient.
Hope that helps some Dr G
Ramon
