new toy
new toy
  • #183631
    mick70
      @mick70
      been given this in with load of old bits from model steam engine club i recently joined.
      seen pic on net of it as lathe.
      not good with comps, does anyone have pics or list of bits that are missing?
      or even link to manual.
      i want to try and make missing bits if possible whilst at club as learning experience.
      cheers
      mick70
        @mick70
        #183632
        Keith Long
          @keithlong89920
          A hint as to what you've been given might help!
          #183634
          Bikepete
            @bikepete
            Mmm, from the page source it seems like your pics are on Photobucket, at:
            Way I did it was to use Photobucket's 'get link codes' button, then 'direct' and copy the code there. Then go back to the forum and hit the image button, paste into the URL line, and hit OK.
            Looks like a useful milling set-up.
            Edited By Bikepete loadsa times, most recently on 18/03/2015 15:49:30
            Edited By Bikepete on 18/03/2015 15:51:49
            #183637
            mick70
              @mick70
              thank you you're a gent.
              i struggle with computers.
              plate on it says
              elliott
              unimat
              sl
              #183638
              Bikepete
                @bikepete
                Manual
                http://www.emco.or.at/index.php/downloadneu/doc_view/48-emco-unimat-sl-english
                Parts list
                http://www.emcomachinetools.co.uk/LinkClick.aspx?fileticket=LY50fXNfWJs%3d&tabid=260&language=en-GB
                Intro vid – the bit you have is actually for drilling not milling it seems – in fact yours looks like a very cut down version.
                Edited By Bikepete on 18/03/2015 16:00:13
                Edited By Bikepete on 18/03/2015 16:05:54
                #183641
                Thor 🇳🇴
                  @thor
                  Congratulations with your "new" toy. I have had one for many years, flexible little machine. I now use it as a small milling and grinding spindle mounted in my (larger) lathe.
                  Thor
                  #183646
                  mick70
                    @mick70
                    i am going to clean it up and paint it and try to get other bits so i have full set-up.
                    #183650
                      Take a look at the Website FAQs, especially on posting pictures:
                      http://www.model-engineer.co.uk/forums/postings.asp?th=103028
                      Includes photobucket specific instructions!
                      Bikepete
                        @bikepete
                        Neil, that advice could do with cleaning up – specificially, it would be less confusing if you deleted your initial suggestion of stripping out tags etc., and all of the subsequent discussion, and just left the post from JasonB at
                        02/01/2015 13:50:18 which shows how to do it the easy way. For a proper job you could edit it to be self-contained i.e. not referring to other unspecified threads.
                        In fact, if that thread is supposed to be a useful help reference, I'd suggest deleting all extraneous discussion and just leave the advice posts.
                        #183780
                        mick70
                          @mick70
                          found loads of stuff listed on e-bay for sl 1000.
                          all mine says on it is sl.
                          it's m12 x 1 as are bits on e-bay will they fit?
