Tip identification
Tip identification
Home Forums Workshop Tools and Tooling Tip identification
  • #181978
    John Stevenson 1
      @johnstevenson1
      Sorting some tips out yesterday from job lots bought over the years and got these.
      Anyone recognise them ?
      Doesn't show up very well in the pic but the radius and nose are ground as opposed to just being pressed in a mould.
      John Stevenson 1
        @johnstevenson1
        #181983
        David Jupp
          @davidjupp51506
          The code on the box is for a triangular insert – so I guess these have been modified to a 'special' (or are in the wrong box).
          #181984
            Ninja throwing tips?
            #181993
            Ketan Swali
              @ketanswali79440
              Posted by JasonB on 03/03/2015 14:25:31:
              teeth 2
              #181994
              Ed Duffner
                @edduffner79357
                I was thinking Ninja stars when I first opened the thread
                Looks like there's a slight taper to the bottom edge on that RH one, Could they be for threading with a special profile .e.g worm gear?
                Ed.
                #181995
                  They might do a butress thread. Or would be handy for making your own broaches
                  Edited By JasonB on 03/03/2015 16:47:00
                  #182003
                  Brian Rice 1
                    @brianrice1
                    One day one might get a sensible answer on this forum when all the school boy a gone to bed if someone ask a question they expect a descent replay not a load of schoolboy drivel. Rant overangry
                    #182014
                    Rik Shaw
                      @rikshaw
                      When all the school boy a gone to bed they expect a descent replay – please don't let them down!
                      Rik (drivelling)
                      #182016
                        Well I did give a couple of proper possibilities
                        Butress form seems to fit quite well with the shape
                        And if plunged in with the cross slide would cut quite nice teeth for a broach blank, easier to see the similarity in shape when looking at a keyway broach
                        Edited By JasonB on 03/03/2015 19:38:55
                        #182027
                        Richard Robinson 4
                          @richardrobinson4
                          The code is for a triangular turning tool, with chip breaker, in a high grade. (http://www.sandvik.coromant.com/en-gb/products/pages/productdetails.aspx?c=tpmr%20221-53%202025)
                          They look an awful lot like the shim to go under an internal threading tip to me, and the grey colour also suggest the "lower" grade these shims are normally made from. Example (http://www.shop-apt.co.uk/shims-seats/yi4-shim-for-22nr-22el-threading-inserts.html). Having three points though does make me wonder if they might even be threading tips?
                          Hope this helps!
                          Richard
                          #182028
                          nigel jones 5
                            @nigeljones5
                            Im erring on the side of Ninja Stars for very little people, smile p They are definitely for thread type cutting as opposed to general machining but exactly what thread would be impossible to say without measuring one.
                            #182029
                            Brian Rice 1
                              @brianrice1
                              Posted by Rik Shaw on 03/03/2015 18:15:01:
                              Rik (drivelling)
                              You picked up on the pigeon English, it was intended.
                              #182031
                                Pidgin – but I doubt the schoolboy humour will be lost on JS.
                                You could use them as pigeon caltraps John, keep the winged rats off the roof
                                Do look like buttress thread form to me.
                                Brian Rice 1
                                  @brianrice1
                                  Here's the part number for these Sandvik tips
                                  R156.3-22 370, 135 P35 22374
                                  #182245
                                  Brian Rice 1
                                    @brianrice1
                                    Posted by Neil Wyatt on 03/03/2015 20:23:32:
                                    Pigun don't not no what you are meaning
                                    #182247
                                      Brian how did you come up with that code? There is a boxed set on ebay with that code but not teh same shape as Johns?
                                      #182248
                                      John Stevenson 1
                                        @johnstevenson1
                                        Close Brian but not quite, those have straight angles sides [ if that makes sense ] probably for ACME.
                                        Mine has curve at the front, curve on the nose and straight on the back.
                                        Probably that special I'll never find out what they are, mind you be happy at £22 a box as i must have 40 boxes or so.
                                        #182253
                                        David Jupp
                                          @davidjupp51506
                                          Looks like a standard tip has been ground for a special job. John did mention ground rather than simply pressed.
                                          #182264
                                          Brian Rice 1
                                            @brianrice1
                                            Posted by JasonB on 05/03/2015 17:38:57:
                                            Yes it was flebay
                                            #182271
                                            Danny M2Z
                                              @dannym2z
                                              A stylised logo for stamping castings produced here:?
