Thanks Mark and Jason.
If I was making both sets of gears from scratch then I would have used Module sizes and 20 pa, however, or unfortunately, the gear I need to make has to mesh with a 32DP, 14.5 pa, which then meshes with more gears so I am stuck for a simple solution.
I have had some success and would like to share this with others who have similar resourcing issues. I contacted a Company called CR Tools in Sheffield who make various tools and they may be able to help, speaking with the chap there, I might get a 40mm OD with 16mm ID with the 32DP 14.5 pa made for a very reasonable sum. (here we go, mixing imperial with metric again- the model makers conundrum!)
If I get a cutter from CR I will post here to advise others on the forum.
Many Thanks
Steve
Edited By Makila on 01/12/2014 10:54:20
