chipmaster motor
chipmaster motor
Home Forums Workshop Tools and Tooling chipmaster motor
  • #170216
    garrygun
      @garrygun
      Hi guys,need to replace the motor variator, what size motor hp would be a good replacement in 3 phase?
      i will probably fit a speed controller at a later date.
      Thanks Garry.
      garrygun
        @garrygun
        #173002
        garrygun
          @garrygun
          Posted by garrygun on 20/11/2014 22:18:28:
          Thanks Garry.
          Any ideas please.
          #173014
          Ian Parkin
            @ianparkin39383
            Same size as was fitted ?
            3 hp 2.2kw should be fine for a chipmaster
            #173050
            garrygun
              @garrygun
              thanks for your reply, there is no info on the motor so couldnt tell what HP.
              Thank you.
              #173077
              Ian S C
                @iansc
                The Chipmaster we had at school 1962/63 had a 5hp motor, the rest of the workshop was run off line shafts driven by a 10hp motor, lathes mills, shapers, etc, etc.
                I'd say a 2hp to 3 hp motor with electronic speed control.
                Ian S C
                #173084
                Alan Jackson
                  @alanjackson47790
                  I have got a 1.5hp 3 phase motor running with an inverter. The variator has been removed, it was ok but takes up too much power. This motor serves me well, it is probably a bit down on power for larger diameters where I sometime have to use the backgear. I would suggest a minimum of 2 hp but this will depend on what you use the lathe for.
                  Alan
                  #173085
                  Keith Long
                    @keithlong89920
                    There is quite a lot of info on the lathes.co.uk website about the Chipmaster and the various permutations of motor and variator that were fitted over the years. You might also get more advice from the Colchester Yahoo group, but there isn't a great deal of traffic on there now after all the messing about Yahoo did.
                    Keith
                    Edited By Keith Long on 20/12/2014 11:02:16
