I fitted an AL-500X to my clone and haven`t seen this problem. The central know seems to be clear of the handle (no rubbing), although mine`s only a year or so old and won`t be getting the proper use you give yours..
Given that this is presumably a fairly std pot with a knob fitted to it, have you tried loosening the grub screw and sliding the knob out a few mm to give clearance? You could also check for swarf and gunge in there.
As for stiffening up the movement, they usually just use some form of grease on the shaft. You probably can`t easily replenish it. Perhaps if you can remove the knob, you may be able to fit a wave washer between the back of the knob and the housing to stiffen the motion up.
Murray
Edit – sorry, Ed, there`s a bad echo in here!
Edited By Muzzer on 24/10/2014 11:22:48
