Boxford drive belt
Boxford drive belt
Home Forums Workshop Tools and Tooling Boxford drive belt
  • #17451
    Nick_G
      @nick_g
      Nick_G
        @nick_g
        I have a Boxford lathe and the drive belt looks to have seen better days (bit like me. frown)
        I have seen various mentions that 'linked belts' are good performers and a worthwhile upgrade to some machines. – So would such a belt (see pic) be suitable for my Boxford or would I also need to change the pulley's.?
        The existing belt is a 10mm width V belt.
        i.e. this type of belt (10mm Z section) :-
        On this :-
        Cheers, Nick
        Edited By Nick_G on 21/07/2014 18:00:45
        #158409
        Bob Brown 1
          @bobbrown1
          The belt would have been marked on the outside if that is no longer visible it is probably easier to take the belt off and take it along to a local belt supplier who should be able to sort out a replacement.
          Or give Boxford a ring on 01422 324810 see http://www.boxford-software.com/spares/X10Guard.html and if I'm correct the belt is a SPZ-737, "Z" section
          If I had the option which I don't I would replace the linked belt on my Boxford AUD with a "normal" one but it has to be split to fit.
          Edited By Bob Brown 1 on 21/07/2014 18:28:36
          Edited By Bob Brown 1 on 21/07/2014 18:42:33
          Edited By Bob Brown 1 on 21/07/2014 18:48:58
          #158431
          Nick_G
            @nick_g
            Thanks for the reply Bob.
            I do know the size of the existing belt but I was wondering if the linked belt may be an improvement in decreased vibration.
            Regards, Nick
            #158437
            Bob Brown 1
              @bobbrown1
              You could try a new standard one as they are not expensive as a starting point, I can see no reason for a linked belt to reduce vibration but again nothing ventured gained.
              #158439
              Roderick Jenkins
                @roderickjenkins93242
                I think the linked belts are more flexible, so will help to absorb any vibration. I remember reading that Tubal Cain replaced the secondary drive belt on his Myford Super 7 with a Brammer link belt and considered it an improvement.
                Cheers,
                Rod
