Thickness Sander
Thickness Sander
Home Forums Workshop Tools and Tooling Thickness Sander
  • #153528
    Stevo
      @stevo
      Hi All,
      Not sure if this is the right place to post this but I'll give it a go.
      I do a lot of work in Balsa, Spruce and Cyparis, occaisionally ash too.
      I needed to sand them accurately to a thickness, and later make a jig so I can make taper sections.
      So what follows is a collection of 12mm birch ply, 8mm stainless threaded rod, a 1/4HP motor (thanks Maurice!) belts, toothed pullies and so on.
      Here goes!
      12mm ply discs cut and sanded approximately round:-
      Shaft bearings:-
      All clamped up!
      Main box, lacquered:-
      Turning the drum round: –
      Machining up some brass bushes: –
      Table pivots, fully adjustable:-
      This shot is sideways, but shows the main leadscrew of 8mm stainless, tothed pully and brass bush, soldered to a strip of 3mm mild steel. There are locknuts either end, adjustable for backlash, of which there isn't any !
      The threaded rod on the right is turns via a handwheel. A toothed belt arrangement turns the rod on the left and the table rises and falls uniformly. All rods are 8mm ball raced:-
      Here's the test pass…baby's bum smooth! The top does have a dust extraction point, too.
      One thing – I've wound the sanding strip (25mm wide) on and secured it either end via screws – not ideal – anyone have any recommendations?
      Thanks wink
      Steve
      Edited By Stevo on 25/05/2014 18:23:39
      Edited By Stevo on 25/05/2014 18:27:01
      Stevo
        @stevo
        #153529
        Bob Brown 1
          @bobbrown1
          Steve,
          How about using hook and loop sanding rolls? you just need to glue the hook part to the drum.
          Bob
          #153530
          Stevo
            @stevo
            Thanks, Bob,
            I did think of that, but can't think for the life of me why I didn't pursue it…
            #153533
              A surface grinder for balsa wood!
              Luvit!
              Bob Brown 1
                @bobbrown1
                Another option may be to cut a groove, deep enough to recess a strip to clamp the sanding roll.
                #153550
                Stevo
                  @stevo
                  Surface grinder for balsa..
                  now that did make laugh!!!
                  #153554
                  Simon Collier
                    @simoncollier74340
                    I made a thickness sander in this way some years back for thicknessing guitar backs, tops and sides. The drum is about 2' wide, 6" diameter. I fasten the sanding roll at each end with strapping tape, which was never really satisfactory but I got the jobs done.
                    #153555
                    Jeff Dayman
                      @jeffdayman43397
                      Nice job Stevo, well done. JD
                      #153572
                      Stevo
                        @stevo
                        Thanks all…
                        Simon.. did you live somewhere near the south coast?
                        When I was a luthier I remember visiting someone near Hastings who built thier own drumsander for guitar fronts, backs and sides!!
                        #153575
                        Simon Collier
                          @simoncollier74340
                          Just slightly off target Stevo; I live in Sydney. The plan for the drum sander was on the internet, I seem to remember, so no doubt a few luthiers made them. It is a scary and dangerous thing to operate, pushing the work against the feed of the drum, driven by a 2 h.p. motor, but surprisingly accurate. Any OH&S type who saw it in operation would have a stroke on the spot.
                          #153586
                          Stevo
                            @stevo
                            Well I wasn't that far out was I? My daughter's backpacking round Australia in October – I'll get her to pop in! laugh
                            "Any OH&S type who saw it in operation would have a stroke on the spot."
                            Indeed… Don't invite them to my house…Dust extraction mandatory…
