Who makes miniature imperial combination or open end spanners ?
Home Forums Workshop Tools and Tooling Who makes miniature imperial combination or open end spanners ?
  • This topic has 15 replies, 9 voices, and was last updated 1 May 2014 at 00:25 by julian atkins.
  • #150989
    Brian John
      @brianjohn93961
      I bought a nice set of small metric combination spanners by Bergen (4mm to 10mm). I am having trouble finding a set of something similar in imperial : starting at 1/8 inch or even smaller. Does anybody know who makes an imperial set of combination or open ended spanners ?
      Brian John
        @brianjohn93961
        #150990
        Martin Walsh 1
          @martinwalsh1
          Try these http://www.baconsdozen.co.uk
          they sell small size imperial spanners
          Best Wishes Martin
          Edited By Martin Walsh 1 on 29/04/2014 07:19:30
          #150991
            Elora do BA open ended and combinations which are quite nice, they may well do small imperial as well
            #150992
            Martin Walsh 1
              @martinwalsh1
              king dick make small imperial spanners
              they are also the highest quality
              http://www.kingdicktools.co.uk/
              Best wishes Martin
              #151059
              Ian Welford
                @ianwelford58739
                I got some 11ba ones from Rufforth car boots sale. However Proops brothers ( on internet) list ba spanners down to 11ba.
                Not ring spanners but OK.
                Ian
                #151101
                Ian S C
                  @iansc
                  When I needed some BA spanners for the Stuart Turner S9 rebuild, I had one 4 BA open ender, I needed a couple of other sizes, and a pair of each, so I made my own out of some little bits of scrap, then polished them up a bit, and heated them blue, I think they look OK, and they do the job. Ian S C
                  #151113
                  Brian John
                    @brianjohn93961
                    Has anybody used these ?
                    They look good for getting into tight and awkward spots.
                    Edited By Brian John on 30/04/2014 13:09:21
                    #151124
                    Roderick Jenkins
                      @roderickjenkins93242
                      Brian,
                      I assume you are in the UK? My experience is that imperial AF spanners fit nothing. You will need either Whitworth spanners (for BSW or BSF) and BA spanners for the smaller sizes. For BA I've got spanner sets by Britool and Terry. The Britool ones are chrome plated and very nice- they look like miniature full size spanners. But the ones I use most are the Terry ones which are stamped out of sheet but are thinner and generally easier to get into tight spots. Whether these are still available is another matter.
                      HTH
                      Rod
                      #151127
                        Looks like the Moody's are well thought of
                        Brian John
                          @brianjohn93961
                          I live in Cairns, Australia. There is very little available here. I buy everything I need from the Uk or the US.
                          #151129
                          Roderick Jenkins
                            OK. I think that imperial AF spanners will fit US size fastenings – perhaps someone will confirm.
                            Rod
                            #151131
                              Posted by Roderick Jenkins on 30/04/2014 18:26:34:
                              Rod
                              Confirmed
                                If using Whitworth and BSF, it's worth noting that Whitworth nuts, and bolt-heads, were originally "one size larger"
                                e.g. a 1/4" Whitworth spanner fit a 5/16" BSF nut or bolt.
                                … Whitworth were later down-sized, to match the BSF.
                                Trevor Drabble 1
                                  @trevordrabble1
                                  Brian,
                                  Amazon list quite a range of BA spanners in a number of different styles including open ended , combination and box spanners.
                                  Trevor
                                  #151151
                                  julian atkins
                                    @julianatkins58923
                                    there used to be a place in nottingham market that sold them loose for less than a pound and all top grade in both imperial and metric down to 12BA (very useful as most of the hex stuff in the smaller BA sizes is now metric).
                                    cheers,
                                    julian
