Well, as I had been good yesterday I was left to my own devices today
Made quite a bit of progress and a picture as they say, paints a thousand words. I just painted the bits instead (RAL 9001 for those of you interested, one of my favourite shades of white):
I had looked at the arm and the cranks and though not overly used the wear marks were apparent in places. This signalled a rethink of the bearing surfaces and the crank action. This was the original crankpin:
The hole in the crank arm has been over-bored already in the above picture and you can see the new configuration here:
As shown in the pic of the main arm I have made some "Top Hat" bushes for this main arm and the smaller crankpin on the sprocket, I made two Top Hats and put them back to back on the sprocket crankpin and the bearing surface is now 10mm diameter as opposed to the original 3/8". I also made new brass bearing covers for the hacksaw frame itself.
Not satisfied with that, I then bored the rear vice jaw, turned the thread back a bit on the bar and turned a groove in it, made a brass retaining plate and drilled and tapped it for the plate:
Oh, and if anyone thinks I have been polishing the bits up you are right. It's a friction thing:
graham.
