New mill being delivered…
Home Forums Workshop Tools and Tooling New mill being delivered…
Viewing 25 posts - 1 through 25 (of 28 total)
  • #17155
    Chris Parsons
      @chrisparsons64193
      Chris Parsons
        @chrisparsons64193
        My new mill is being delivered on Friday (wahoo) and I am trying to anticipate what I need to get started, with the proviso that having just stumped up a lot of money *sob* I am looking for the minimum at the moment?
        I have bought an ER32 collet chuck, collets from 6 – 12mm, a set of workpiece clamps, and will nip up to Tracy Tools in the next couple of days to get some HSS end and slot mills – they do sets from 3 – 12mm which I thought would get me started, perhaps with a few extra spares – not sure which sizes to get extra having said that….
        I have the normal stuff for using with my lathe, measuring, marking out and so on – can anyone suggest anything else that they would consider to be really essential to get going?
        Chris
        #128405
        jason udall
          @jasonudall57142
          Something to chew on other than the bed or work holding?…..
          #128408
          MICHAEL WILLIAMS
            @michaelwilliams41215
            Hi Chris ,
            (1) Machine vice – easy enough to make if money is tight .
            (2) Avoid cheap selections of milling cutters .
            You can get quality cutters for not much more .
            (3) Flycutter and or an inserted bit facing cutter .
            (4) Cutting oil and means of applying – brush or squeeze bottle will do .
            (5) Parallels and packing .
            Need not be bought as such but build up a stock of useful bits of bar for supporting work .
            Lots more things may be needed but just acquire as needed .
            Regards ,
            MikeW
            #128416
              DTI to set the work and vice true.
              Edge & centre finders
              J
              Edited By JasonB on 02/09/2013 13:36:20
              #128419
              Geoff Theasby
                @geofftheasby
                A drill chuck…?
                Geoff
                #128420
                mechman48
                  @mechman48
                  Chris
                  What mill are you getting?
                  ER 32 collet sets come with up to 20mm dia cutter collets, have you bought them separate? could end up more expensive buying them individually?
                  Rotating tailstock center !
                  George
                  #128424
                  PekkaNF
                    @pekkanf
                    Two pieces of advice:
                    1) Stop spending. Don't buy any cheap tools until you absolutely need them. Then buy ONLY tools you need and quality.
                    2) If you are any new to milling buy a book "Milling: A Complete Course" Harold Hall. And in meantime visit his site:
                    http://homews.co.uk/page463.html
                    Some of the clamps and other workholding equipment can be bought, but quite a bit is least as good when made at home.
                    PekkaNF
                    #128425
                    Thor 🇳🇴
                      @thor
                      Hi Chris,
                      I agree with the advice given by MikeW. If you want to make your own vice here are a few webplaces that may be of interest:
                      Screwless vice, another one, I made a similar one myself. Dean's version.
                      One from CNC zone
                      Thor
                      Edited By Thor on 02/09/2013 14:22:46
                      #128426
                      Chris Parsons
                        @chrisparsons64193
                        Jason U – I smiled and then thought good point, most of my 'stock' is round bar!
                        Michael – I am going to have a go at making a 'split' vice as in Howard Hall's book so I can mount work directly on the table, and hold off on the commercial vice – they are expensive (looked at a Vertex VA4 but think it might be too big for the table?) Already got a flycutter on a straight shank but may eventually get one with a taper. Got cutting fluid (use it on lathe and bench drill) Got parallels but good point about packing – might also make some of my own clamps/fences (good practise)
                        Good source for quality cutters? With no experience it's hard to judge good or bad…most of the stuff I get from Tracy Tools seems OK?
                        Jason B – Already got a dial indicator, DTI and an edge finder but not centre finder (yet) Bought a mount to fit the DTI to the quill (looks like an Indicol?)
                        Geoff – comes with a drill chuck fortunately (one less thing to buy)
                        George – got an ER32 set from ArcEuroTrade with chuck and 6 collets in case – 6, 8, 10, 12, 16 and 20mm? Rotating tailstock center??? I have one for the lathe but it's MT2, what would I use this for on a mill? Oh, and the mill is a Sieg SX3
                        Thanks for all the suggestions, if you don't ask you never learn
                        One other thing is the issue about clouting the drawbar to get the (MT3) taper out – been trying to visualise the various posts about self extracting drawbar modications
                        I went for MT3 in the end so I could use the tooling on the lathe
                        Cheers
                        Chris
                        #128431
                        Russell Eberhardt
                          @russelleberhardt48058
                          My most useful accesory, after the assorted clamps (homemade) is the angle plate.
                          Russell.
                          #128438
                          GaryM
                            @garym
                            An IKEA Jansjo lamp? £10
                            Gary
                            #128464
                            Sub Mandrel
                              @submandrel
                              Most used accessory?
                              After the vice (with apologies to Harold "Clamp Evangelist" Hall!) my home made ER25 chucks, my self releasing drawbar and then my rotary table (but I do like making gears and wheels etc.)
                              To be fair to Harold, he's obviously travelled the road to Damascus, having just given us a series on milling vices!
                              Edited By Stub Mandrel on 02/09/2013 22:01:47
                              #128468
                              GaryM
                                @garym
                                A simple mod I made to mine was to add four M12 washers to the X-axis feed handle to keep the dog clutch permanently engaged.
                                Gary
                                #128475
                                Geoff Theasby
                                  @geofftheasby
                                  Re: clouting the drawbar to release the taper. I have suggested using a rubber hammer, but I find now that it is less effective than using a light steel hammer to tap the drawbar end. Not a heavy blow, just enough to release it. This implies that you don't need to tighten the spindle very much in the first place. Just nip it up. You will soon get the feel of it.
                                  Geoff
                                  #128491
                                  Robbo
                                    @robbo
                                    Just a point on hitting the drawbar. Hard faced Thorex mallet is the thing. If you use a metal hammer, be sure to wind the drawbar nut up to the top of the threads so as not to burr the thread over.
                                    Phil
                                    #128493
                                    Paul Lousick
                                      @paullousick59116
                                      I have the same mill and also chose a 3MT version so I could use my lathe tools. Don't overtighten the drawbar. I use an aluminium hammer to release the tools but cringe every time I hit it.
                                      As previously said, buy quality tooling as you need them. Keep an eye on e-bay for good used tools. A quality used tool is far better than new asian junk. You can also make lots of your own.
                                      Happy machining.
                                      #128495
                                      Russell Eberhardt
                                        Posted by Paul Lousick on 03/09/2013 11:01:25:
                                        Same here, but I always lock the quill before hitting it to keep the shock, such as it is, off the rack.
                                        Russell.
                                        #128497
                                        Chris Parsons
                                          @chrisparsons64193
                                          Thanks for the additional information – I have both of Howard Hall's milling books, excellent guides – and will be making a good bit of the tooling myself
                                          Think perhaps I am worrying about the drawbar removal too much, I will not overdo it and I already have a copper/hide hammer which I will use to save the drawbar top and locking the quill first is an excellent suggestion
                                          Thanks Thor for the links to the vices – the first one was an excellent site, keep me busy for months, there is loads of stuff on there I am thinking about having a go at now
                                          Think I have worked out the principle of the self releasing drawbar now so this is an alternative too
                                          I don't subscribe to any of the options so missed the series on milling vices which was mentioned – and even if I did now would not get the 'back issues' ??
                                          Two days and counting…
                                          Chris
                                          #128506
                                          GaryM
                                            @garym
                                            Chris, the drawbar on the X3 doesn't have exposed threads on the top end. It's a hex socket and so unlikely to damaged. I went for the R8 as a result of reading many threads on which taper to choose. Never needs more than a light tap.
                                            Gary
                                            #128509
                                              Doesn't the X3 have a slot in the quill for MT3 tool 'persuasion'? I keep forgetting it is there on my old Warco minor.
                                              The other thing for tool removal is a pair of those U shaped wedges.
                                              #128606
                                              Norman Lorton
                                                @normanlorton75928
                                                I do apologise to all you MT3 people, but I agree with Gary. I am sure that the MT3 works fine in holding tooling but R8 holds and then lets go when you want it to.
                                                Edited By Norman Lorton on 04/09/2013 21:40:31
                                                #128607
                                                Sub Mandrel
                                                  @submandrel
                                                  That's exactly what the MT series tapers were designed for.But a different philosophy. MT series are self-holding tapers, R8 and INT30 are not self-holding and need drawbar for all uses.I have not had any problems with removing MT3 since I made a self-ejecting drawbar that puts no strain whatever on the bearings.
                                                  Chris Parsons
                                                    @chrisparsons64193
                                                    A final thank you to everyone for all the advice – the new mill was delivered on Friday, dismantled, moved to it's home and cleaned, lubricated and reassembled and was making chips on Saturday afternoon so I am a very happy man – now all I have to do is learn how to use it!
                                                    Here are a couple of photos, as it was delivered
                                                    and installed ready for use
                                                    …and yes, it was very heavy and I was glad of the help to lift the base and column onto the stand, thank you Gary!
                                                    Chris
                                                    Edited By Chris Parsons on 09/09/2013 14:03:08
                                                    #129049
                                                    Russell Eberhardt
                                                      Enjoysmiley
                                                      Russell.
