I milled a series of fine channels on the tool rest, that way the dust that comes off goes into the channels rather than getting trapped underneath the tool when you are sliding it side-side. Makes the thing operate more smoothly.
Then I thought… hey, what if I cut somewhat deeper channels over a plate and also on a second one (or a jig), then when placed together the top one would slide orthogonally L-R on it and could also be easily repositioned in relation to the grind wheel as required. Just a thought…
I also received the diamond dresser – which is why everything in there is covered in dust
,,,and Warco emailed me to say they are send a replacement Green Grit wheel because the one I received got a little bent in the post:
Edited By Chris Heapy on 28/05/2013 14:34:15
Edited By Chris Heapy on 28/05/2013 14:38:15
