AHHHHHHHHHHHHHH
AHHHHHHHHHHHHHH
Home Forums Workshop Tools and Tooling AHHHHHHHHHHHHHH
  • #107598
    jim both
      @jimboth37830
      just checking a thread, been through TWO new thread gauges and they are BOTH missing 1.25mm pitch blades!!! one of them has TWO 1.5mm pitch blades!
      Doesn't matter too much as the thread was 16 TPI, but annoyed me!!
      back to the shed!
      jim both
        @jimboth37830
        #107666
        Sub Mandrel
          @submandrel
          At least you can find yours. Mine hid behind the bench years ago
          DMB
            @dmb
            Neil,
            I still have an old relative`s watch-making bench. It has a small fence around the edges to stop items taking a run for it. I have copied this for another workshop bench.
            Happy New Year to you and the rest of the forum members.
            Sub Mandrel
              @submandrel
              Hi John,
              I have a door on the workshop. I'm not convinced its stops anything making a run for freedom
              I recall that jewellers used to wear leather aprons pegged to the bench to catch all the gold dust.
              Ian Abbott
                @ianabbott31222
                The tool fairies stand on each other's shoulders to reach the door handle.
                Ian
                #107729
                Dusty
                  @dusty
                  I have a workshop Gremlin it has a habit of creeping out while I am otherwise occupied and moving and hiding things, I have blocked all gaps, even fitted kickboards (removable) under the bench. It has all been to no avail. I even went to the extreme of tidying the bench, it did improve things for a while but but the little so and so has overcome even that. I wouldn't mind but she (she must be a she) hides things and then puts them back where I had originally put them. I don't know what the answer is!
                  #107732
                  Andyf
                    @andyf
                    I've got a similar gremlin, Lofty. It comes into the house sometimes, and must be missing a leg because it only takes one sock out of the washing machine, not a matching pair.
                    Andy
                    #107736
                    1
                      @1
                      Andyf, are you sure she is taking a sock out and not putting an extra one in just to wind you up?
                      Jim
                      #107764
                      Ian S C
                        @iansc
                        All workshops/ workplaces are infected with Gremlins, you'll find them in every country in the world, and they are the same every where, and although there are millions of them, nobody has caught one yet. Adam proberbly had one in the Garden of Eden, and he definitely had one when he left the garden. Ian S C
