3 jaw chucks
3 jaw chucks
Home Forums Workshop Tools and Tooling 3 jaw chucks
  • #106558
    Ronald H Farquharson
      @ronaldhfarquharson33355
      Is it possible to true up a rather inaccurate 3 jaw chuck?
        #106567
        KWIL
          @kwil
          If it has got to the stage of "rather inaccurate" it is clearly worn out and many parts must have excessive play and wear. The best you could achieve would be an "improvement" at one holding diameter and once away from that point, no better.
          #106570
          Brian Wood
            @brianwood45127
            Hello Ronald,
            Yes it is, much depends on what IS inaccurate. If it is the rear plate mounting to the chuck, that is a relatively easy salvage which involves turning away the old location, bonding on a ring to replace it and turning the new register to suit the chuck.
            The second fault concerns the chuck jaws that may have gone 'bell-mouthed' with being forced to grip just on the tips [a form of regular abuse].
            You will need a toolpost grinder or similar to correct this fault. First turn a ring with a reasonable aperture, open the chuck jaws outwards to grip it on the outer steps and then very carefully grind new gripping faces onto the INSIDE facing jaw surfaces. Move the grinder in and out with the chuck rotating slowly to cover the whole surface until the shine is even throughout on all three jaws.
            Test the results on a true bar for runout and repeat if you have to. If the body guides to the jaws themselves are badly worn and sloppy it is best to scrap the chuck and fit a new one.
            Take care to remove ALL grinding dust after, cloth protection on bedways is good before you start.
            You may well find in the end it is only fit for roughing work, in which case keep it for such.
            Good luck Brian
            #106572
            MadMike
              @madmike
              Ronald, define inaccurate. It is only a holding device remember. The turned product should still be round regardless of the condition of the jaws or scroll. However if your headstock bearings are shot then you may get inacuracies when turning.
              If you are trying to relocate a turned part and get it to run true then it is unlikely that any 3 jaw chuch would do this with any degree or accurace or repeatability.
              A bit more information would help us in identifying a solution, if there is one. HTH.
              #106592
              Brian Wood
                @brianwood45127
                Hello Ronald,
                There is another, rather tedious way of correcting bell mouthed jaws, I used it many years ago to put my father's small scroll chuck right when it came to me with the Myford ML4 lathe after he died. You need a LOT of patience!!
                Use a black magic marker to coat the jaw gripping surfaces first. Then, with a true and round bar in a tailstock chuck you trust, close the 3 jaw chuck down until only one jaw is touching the 'test' bar. Idle the lathe at slow revs, move the testbar in and out to rub the marker away on the jaw that touches.
                Take the jaws out and with a fine oilstone, polish that jaw over the bright area, holding it carefully to grind only that bit. Rebuild the chuck and test again with remarked jaws, repeating the process until you are satisfied that all 3 jaws grip evenly both front and back. This also means checking for runout as the polishing proceeds. Look especially for any misalignment along the lathe axis where the chuck tries to grip on the back or front of a jaw. That will show up as increasing displacement of a DTI along the length of a true test bar. Axial displacement alone is parallel to the lathe axis.
                As I said, you do need lots of patience; in my case I was rather fond of the lathe and this little chuck, it is now amongst the best in my collection, so it does work.
                Brian
                #106621
                Lambton
                  @lambton
                  Before doing anything drastic I suggest that you strip down the chuck and clean the scroll, gears, inside the body etc. It is surprising how much swarf collects inside a 3 jaw chuck and some can be come jammed in the scroll which causes one or more jaws to be slightly displaced.
                  Whilst chuck is off the back plate check that the register is running true. If it is not look for any damage to is where it interfaces with the lathe spindle. If you are SURE that it is properly seated on the spindle there may be enough "meat" left to re-machine the register.
                  When chucks get a little worn it is a good idea to use the same socket each time for tightening. Do a bit of experimenting to find the one which gives the best result using a known round bar and a DTI then paint it red.
                  I have found that these measures often greatly improve the accuracy of a used chuck.
                  #106658
                    Thanks for your help. You have given me some ideas.
                    #107590
                    garrygun
                      @garrygun
                      Hi ronald,heres a link you could look at,i have seen a dremmel or equivelant used.**LINK**
                      Garry
                      #107591
                      Chris Trice
                        @christrice43267
                        The problem with that video is the jaws are being tensioned inwards by the acrylic ring. The scroll and jaw teeth don't tend to wear so much in that mode. He should be tensioning the jaws outwards in the same way they would be when holding something. I've actually done this with an old chuck (not too knackered) and got the thing to hold amazing true throughout it's full movement. Don't forget to use the same key position each time too and mark it somehow. I turned up what was essentially a top hat with the very top of the hat missing. I took out three section of the tube on a rotary table with an end mill slightly narrower than the thickness of the jaws. I then gripped this in the chuck with the jaws in the gaps so I could then send in a small grinding wheel on a flexible drive clamped in the tool post. You only need to take the barest minimum off.
                        #107593
                        Chris Trice
                          @christrice43267
                          … continued.
                          Not only do the jaws tend to wear bell mouthed but they also tend to wear so that they can tip, again causing the grip to only happen at the back. Using the top hat method, all slop is taken out and the jaws ground to hold truly parallel. Obviously the jaws need to be well made to grip the top hat on their angled faces fairly accurately (most are) but even a slight sideways deviation make negligible difference. Don't forget the more you grind off, the larger the minimum diameter the chuck can go down to.
                          #107594
                          Siddley
                            @siddley
                            I think it depends on how 'mullered' the chuck is to begin with.The Pratt-Burnerd which came with my Hofmann dividing head had jaws which looked like someone had been beating them with a hammer.
                            I used all the methods outlined above to try and correct the problem ( including toolpost grinder ), but nothing worked.
                            #107609
                            MICHAEL WILLIAMS
                              @michaelwilliams41215
                              From an earlier posting :
                              Grinding out the jaws of any self centering chuck while the jaws are loose will give uncertain results at best since the jaws are not loaded and the clearances not biased in the same way as when gripping a workpiece .
                              Any self centering chuck can have jaws corrected simply by putting a round aluminium bar lap in the tailstock , covering it with grinding paste and working it back and forth through chuck jaws . Jaws are gently and progressively closed down onto the lap as work proceeds . All loads and clearances of jaws during lapping process are the same as when gripping so maximum accuracy is achieved .
                              For best results turn down most of the aluminium bar slightly leaving just about one inch long as the actual lap and in the final stages of lapping run the lap almost completely out of the jaws at both ends of stroke .
                              Takes about twenty minutes .
                              Michael Williams .
                              #107625
                              Gordon A
                                @gordona
                                Ronald,
                                As I understand it, the jaws should be pulled outwards as close to their ends as possible when grinding to overcome the effect of "bellmouthing".
                                I have constructed the contraption shown, and so far have attacked 2 worn 3 jaw chucks with very satisfactory results.
                                http://ebookbrowse.com/chuck-truing-scan-pdf-d379399518
                                Gordon.
                                #107629
                                joegib
                                  @joegib
                                  A much simpler device for holding the jaws under the correct outward tension required for grinding is a set of sprung wedges of the type shown here:
                                  Wedges
                                  Fitting is best done with the backplate spigot lightly held in the vice jaws so the chuck is horizontal as the jaws are tightened against the wedges. Best to use a full-face mask when grinding using this technique, though.smiley
                                  Joe
                                  #107702
                                  _Paul_
                                    @_paul_
                                    Posted by MICHAEL WILLIAMS on 31/12/2012 10:36:14:
                                    Michael Williams .
                                    Michael,
                                    Thank you very much what a great tip, after stripping/cleaning the scroll licking off the burrs and skimming the backplate on my very old "The Burnerd" 5" chuck it still had very poor repeatability just tried your idea and now have repeatability to about 0.001" not bad for a chuck which must be >60 years old
                                    One thing I will add my chuck jaws do have a little sideplay so in an attempt to counteract this I ran my Boxford both backwards and forwards whilst lapping, this did produce a visible "facet" on the ground surface of the jaws but seemingly no ill effects.
                                    Thanks again
                                    Paul
