As an edit to my 2nd post I,ll change the wattage figure for the converter from 1100W to 1500W, apologies.
The very quick calc is one I was given by an instructor at Maddon generators more years ago than I care to remember and is the one I,ve used at work to calculate the generated output required to start a motor of any size (3PH) from a mobile/portable Genset— works for me— for the previous 35 years. Just use Ohms law to apply it to motor Wattage.
I do agree that the L1 figure is "iffy" but is probably correct given that the inverter is driving L2/L3 through capacitors. Small changes of capacitor values serving L2/L3 would give more balance to the circuit.
Doing the calc L1+L2+L3 in running Watts= 776 W, so given the motor/winding temp 1100/1300 W is somewhere very close.
The motor/winding temp will fall with better phase balance.
Do the calc, Total V(L1+L2+L3) divided by Total A (L1+L2+L3) This also puts you somewhere close.
There will always be variation due to temp and stopping/starting a motor during testing will always make it worse as the motor does not dissipate start up heat until it,s been run for a while.
Nathan.
Edited By Nathan Sharpe on 13/09/2012 23:39:34
