This is my first posting on this forum and I am delighted with all your help, thank you. I had a look on the RS link which is exactly the thing I'm looking for. There is even an identical light to the one fitted to my Bridgeport, so I might buy one for that as well. All at much more reasonable prices.
Ian SC, the fasteners are all cosmetic rather than anything internal or stress loaded, makes an enormous difference to the overall appearance of the machine. I have ordered a piece of stainless sheet to go on the cabinet tray under the bed so when cleaning away the swarf it doesn't take all the paint with it. I'll need to cut around the mounting points of the bed to the cabinet so as not to disturb the accuracy of the machine. I shall seal it with Sikoflex so any oil or swarf doesn't work it's way underneath.
With regard to the 240V light, what about a transformer 415V to 240V instead of the low volts one fitted? Or would it be better with a low volt bulb? Can't see that it would be a problem, but welcome your input.
Mickypee
Edited By mickypee on 16/06/2012 15:50:49
