Well….. the FC 3 cutters are all 3 flute cutters and they are excellent for slots. Use them exclusively for all small sized slotting. Tend to give a better finish due to lower levels of vibration by reducing springback in the tool.
The trick is to have a rigid mill, and a decently held bit of work, and to cut at the correct speed AND toothload. A 1/4 " FC 3 (which is not far off a 6.5 mm cutter – .264) will cut very well at 2000 rpm though 1500 RPM is about 100fpm. Thats more or less what I cut at all the time, simply because its a recommendation for a general purpose steel, and it happens to be the H2 ratio on the mill.
If the stuff is EN3b, it is common or garden free cutting mild, with a direct equivalent of 070M20 in new money. Nothing special – just lovely soft stuff specifically for machining.
So Andrew has to be right – its either the feed rate, which shouldn't be more than a couple of thou per tooth per rev, or the cooling is up the duff. Might not be enough, or it could be neat that should be dilute so one is not getting the flow removing chips, or heat transfer out of the work. As Andrew suggested, 2k RPM might be trotting on a bit, but it is not outrageous – but the 600s as suggested are probably way too slow, because the likelihood is that one will have far too high a tooth load which leads to tool bending and breaking. Still, if one has a blunt cutter, the wise thing to do is to maintain revs, and increase tooth load slifghtly to prevent rubbing.
Edited By mgj on 22/02/2012 17:40:54
