Well John, looks like you need another new keyboard, the caps lock is sticking
Mills want watching, being tall with a relatively small base they love to fall over. I saw a cautionary tale on the web once about two guys trying to get one off a trailer. They were sliding it down a couple of boards since they had no hoist or anything to hang one from. The handles were off to avoid damage to them. Naturally the mill fell off the ramp, and one of the spindles went through the calf of one of the guys, pinning him to the ground. So the other guy rushes madly around trying to get the machine up and off his mate…result, it slips again, resulting in another hole through his calf.
So there is quite a lot to be said for partially dismantling machines, especially if you can get them down to manageable components. Another idea is to construct a very solid base from heavy timbers and bolt the machine to it, so that you have a stable base that is smooth enough underneath to move the whole thing on rollers.
Be very wary of the dudes with forklifts, they have exagerated ideas of what they can do and will cheerfully bend the leadscrew of your lathe. You can do a lot of damage with a forklift very quickly. Getting machines on and off a trailer or truck usually requires some sort of hoist. Moving them about in the workshop is often best acheived in a very low tech way with steel rollers made from either good solid pipe or better, solid bar, which only needs to be about 1 to 2 inches diameter. For some machines you will need the above mentioned base, for others you may be able to just roll it all on the machines base….this works well with the bigger shapers. Since the machine is only an inch or two above the floor, there is not very far for it to fall.
Be very careful, crush injuries are very nasty. You don’t want loads of people, they will just get in the way, but don’t be alone either. Make sure everyone is very clear about what is to be attempted, and don’t ever let anyone get under a suspended load
An engine hoist that will manage 1 tonne is quite cheap these days, and most of the machines we are likely to want to move either fall within this capacity, or can be taken down into sections that do.
regards
