Thanks for all the advice so far. Yes, i think the RT will definitely be used with a chuck, but the vertical travel on the table shoudnt be a problem, its a pretty big mill really – or i think it is.
A bit more info, the table is 27X8″, the table travels 18X7″ (approx), with 12″ vertical travel on the table (although it looks more, Ill measure it later to make sure its right).
Im sure an 8″ RT would fit ok, even with an angle plate attached to the RT. BUt it is pushing the mill (dimensionally) to the limit i guess.
I think Ive settled on getting a 6″ RT, unless the general consensus is that Ill regret not getting the 8″ when the mill will probably handle it.
Thansk once a again for all your input, its very much appreciated to get the advice off people who use this type of equipment..
Steve
