You could fit the mk1 super7 headstock to the ml7 bed, same bed, but you would have to also fit the super 7 motorising bracket, countershaft and pulleys as well, better off buying a super7. You mention ptfe tape , Is Your problem that you are not throttling the oil control correctly, if you have to fast an oil feed, the oil will build up above the bottom of the sight glass lower edge and leak through the sight glass suround ! Being a total loss lubrication system it will always leak a bit around the bearing sides, but i reckon your main problem is giving it too much oil in the first place, a drop a minute max! cheers, mick.
