slitting saw woes
slitting saw woes
Home Forums Workshop Tools and Tooling slitting saw woes
  • #41791
    wheeltapper
      @wheeltapper
      Hi
      I recently bought a slitting saw from company A with a spring loaded arbor.
      on setting it up in my mill ( in a collet chuck ) I found that it ran off centre and only one or two teeth were cutting, the rest were just along for the ride.
      at first I suspected the arbor so I made my own, turning it in a collet and making the diameter a snug push fit for the saw.
      same result, chonk..chonk..chonk.
      so I bought a saw from company B.
      same result  chonk..chonk..
      question, are all slitting saws crap or does someone out there sell decent ones
      cheers
      Roy
      wheeltapper
        @wheeltapper
        #41793
        David Clark 13
          @davidclark13
          Hi There
          Try buying a recognised brand such as clarkson or dormer from Ebay.
          They should be fine.
          regards david
          #41799
          wheeltapper
            @wheeltapper
            Hi
            nice idea but they seem to be as rare as hens teeth
            cheers
            Roy
            #41802
            Steve White
              @stevewhite78094
              Hi Roy, if it’s any consolation, my milling cutters and slitting saws all do that on my Tom Senior horizontal mill. I thought it was the arbour so i made another one myself and had it running so true  could hardly measure the run out  -same result as you, chonk chonk! I hoped that every time I put a cutter on the arbour, it would be in a different position so any wear would even it self out…..hmmm, not sure.
              Even so, it’s a bit frustrating having all those teeth and only a few doing anything useful.
              Incidentally, all my cutters are good quality but some are possibly resharpened as they are second hand…….
              Best of luck
              Steve
              #41810
              Jim Whetren
                @jimwhetren72358
                When I had the chonk..chonk.. problem with a 4″ saw I was using to cut con rod strips from a piece of 3/8″ plate, I used a Tinker jig to take a lick off the tip of each tooth.
                This resulted in a satisfying zzzzzzzz.. when I used it again.
                Whatever method is chooen to give the teeth a ‘touch up’, the important thing is to have the close running mounting boss stationary and rotate the blade around this using a piece of spring steel to index each tooth.
                That way the teeth must be concentric with the bore.
                I hope this helps
                Jim
                #41812
                wheeltapper
                  @wheeltapper
                  Hi guys
                  thanks for the replies.
                  I was beginning to think it was me, being a newbie to this game, but;
                  I just fitted a dial gauge to the milling machine bed and checked various things, total runout on the spindle is half a thou, its a chester conquest mill so I wasn’t expecting miracles.
                  fitting the collet chuck and clocking the outside gave me half a thou so the chuck is OK.
                  fitting my home made saw arbor and checking that gave me 1 thou total runout.
                  fitting the saw , placing a feeler gauge tween tips and gauge and running veeeery slowly gave me a staggering 22 thou runout.
                  so its not me.
                  Jim,
                  thanks for the tip, I am making Harold Halls grinding rest at the moment so when that’s finished I’ll have a go.
                  I can’t make them any worse can I
                  cheers
                  Roy
                  #41826
                  Steve White
                    @stevewhite78094
                    Some good advice here, thanks Jim.
                    Roy, can you point me in the right direction for the grinding rest details please, is it an article in ME?  I think I’ll have a go at it as well.
                    I’ve been at this game a few years, but not being a professional, I thought it was me also – I still do! I suppose it’s best not to make assumptions.
                    Many thanks
                    Steve
                    #41831
                    wheeltapper
                      @wheeltapper
                      HI Steve
                      the rest I’m making appeared in Model Engineers Workshop issue 109.
                      there is a slightly more complicated one, again by Harold, in MEW issue 89 but I’m not into complicated yet
                      can I post piccies on this forum?
                      I’ve got a photobucket account I use on other forums so I could show how I’m doing.
                      cheers
                      Roy
                      #41844
                      David Clark 13
                        @davidclark13
                        HiThere
                        Harold Hall’s tool rests have both been published in his books.
                        One was in his tool and cutter grinding book, and I think the other may have been in his complete milling book.
                        regards David
                        #41846
                        wheeltapper
                          @wheeltapper
                          Hi
                          I just discovered I can have a photo album so I’ve put on some pics of my grinding rest .
                          I’m quite pleased with it for my first serious project.
                          cheers
                          the chuffed side of Roy
                          #41861
                          John Wood1
                            @johnwood1
                            Steve, Harold Hall’s grinding rest is fully described in ‘Tool & Cutter Sharpening’ book which is number 38 in the Workshop Practice Series, many adverts available as well as http://www.specialinterestmodelbooks.co.uk
                            I have built this recently but find it perhaps a bit too comprehensive in that in an attempt to provide a table/rest to grind just about everything it makes it quite fiddly and laborious to use in some instances.  I normally wish to gring lathe tools quickly but it takes me all evening to do one.
                            Having now seen the grinding rest in the Myford Series 7 manual, the table of which extends both sides of the wheel, allowing tool grinding to be done very quickly and at the correct angles I reckon this would best suit my purposes.
                            Bizibilder
                              @bizibilder
                              Hi
                              I’m a bit late here as Jim Whetren has given the answer – sharpen in a jig on its own arbour or life is just clonk…clonk…clonk
                              Bizibilder
                              #41963
                              wheeltapper
                                @wheeltapper
                                Can anyone tell me where I can get a 6″ saucer wheel so I can grind it properly.
                                cheers
                                Roy
                                #42558
                                Jim Whetren
                                  @jimwhetren72358
                                  Hello Roy,
                                  To sharpen saws on the Worden I used a diamond wheel from Arc Euro Trade.
                                  D4BT9 15 Deg. Taper Page 22 of the catalogue.
                                  This gave excellent results with such items requiring a fine edge to the grinding wheel, gashing end mills for instance.
                                  Jim
                                  #42562
                                  Ian S C
                                    @iansc
                                    Spose’you could put the mandrill in the 4 jaw and center it,but then again t might not be round anyway.Ian s c
