Re the oil blacking in my lever tailstock thread, I did a few trials on the bits for the lever tailstock and before that on some other projects I made. I found that heating the bits up to lower temps, blue or even up to grey etc work ok-ish but the layer of black was a bit thin, inconsistent and tended to rub off with use.
On the lever tailstock bits, I heated them until they just started to go a slight dull red, then held them there for a bit to let the heat soak right through the job, then plunged them into the clean motor oil, jiggling them up and down as I moved them around in a circle so that pockets of oil vapour did not form and surround the job. I reckon that by the time I moved the job from the bench with the torch and hearth on it to the next bench with the oil on it, the job had pretty much lost its red colour so it does not seem critical. I did leave the job lying in the oil until it had completely cooled off. Then wiped them off and sprayed down with WD40 and let it soak in. This last seemed to help generate a nice shiny black finish.
The result of this was that seven months later the lever tailstock black bits still look great and have proven quite durable in finish.
I have also done the small sensitive drilling attachment this way and it looks very good too.
Obviously, if the job were made from silver steel or other higher carbon steel where red heat would affect temper etc I would use lower temps for blacking. But for mild steel this works well for me.
Edited By Hopper on 31/12/2022 02:58:20
