I will split my casting blunders and successes out into a separate thread, since this may take a while.
I am going to post my blunders because sometimes it is as important to understand what does not work, as it is to understand what does work.
And perhaps seeing the progression from blunders to consistent castings will help others see that things can be rough in the foundry world when one is trying to learn the methods.
I was trying to learn 3D modeling, and learn how to make 3D printed patterns, and so I printed the frame for one of my dad's small oscillators.
At the time, I didn't even know how to machine metal, and so it was sort of like a blind man hiking through a mountainous region full of cliffs and crevasses. If you fall down, you get up and keep hiking.
Result: These two castings actually turned out relatively well, with just some slight porosity on the top of the bearing supports. I never used these castings because at the time I didn't know how to machine or build engines.
I did learn how to fill a flat 3D printed pattern to give the surfaces a nice concave shape.
A friend of my brother's got all excited about my new casting abilities, and insisted on a demonstration.
I was a bit nervous, for good reason, because I still had very little idea of what exactly I was doing.
I discovered (after the pour) that if the same diameter pins were used on either side of cope and drag, then the cope could be installed in a position that was 180 degrees off, and thus the upper part of the casting is shifted over about 1" from the lower part of the casting.
My brother's friend was not impressed, and he never came around again for any more castings sessions,LOL.
One of those fair-weather casting friends I guess; always there for the glory; never to be seen for the failures, LOL.
Results: Abject Failure, but important lesson learned. Use a 1/4" pin on the left side of the flask, and a 3/8" pin on the right side of the flask. Orientation problem solved.
Having had some limited success with casting 356 aluminum, I decided to set my sights on casting gray iron.
I made my own siphon nozzle burner using a cutting torch tip, with the oil flowing through the center tip hole, and the compressed air flowing through the outer ring of holes.
This burner actually worked very well, but unfortunately I had no idea about what the optimum fuel/combustion air/compressed air levels where, and so I literally just stumbled through this melt with blind luck.
This was my first iron pour, and I used petrobond.
Petrobond can be used sometimes with iron, but it does not stand up to iron temperatures well, and so I did have a few sand inclusions in this casting, which I filled with JBWeld.
Result:
For a first attempt at an iron pour, I considered this a success, with a few defects that could be repaired.
I opened the mold while the iron was still hot (after removing my facemask), and the cloud of smoke burst into flames just as I leaned forward to look at the casting. I saw the flames coming and closed my eyes, and that is the only reason they don't call me Stevie Wonder now. Petrobond smoke is highly flamable; remember that.
The iron machined easily, even though I did not use ferrosilicon, being unaware of it at the time.
I made a pressurized diesel fuel tank from a NEW 40 lb propane tank (don't cut or drill into a used propane tank; it will explode), and this helped stabilize the burner.
I went to the used sporting goods store and purchased several weights to use on the top of the flask.
Crucible was a Morgan Salamander Super B30 (bilge shape).
Iron was Class 40 iron bar stock.
Fuel was diesel with home-made siphon nozzle burner.
I fear the moisture that would be in the sand more than I fear the concrete exploding.
I have spilled a lot of metal including iron on my driveway, and since it is rather old concrete, it does not explode.
Spilling molten metal on wet sand could definitely explode, and you would only need a slight amount of moisture in the sand.
I know of an iron caster in Australia who has poured iron over concrete for 20 years, with no sand, and he agrees with me that sand is not necessary.
I have seen someone spill aluminum on some relatively new and hard concrete, and it did spald the surface.
I also saw someone use concrete to build a furnace, in lieu of castable refractory, and that furnace did explode violently.
The sand would probably serve more as a protection for the driveway, but my driveway is not so great, so I don't worry about it. And sand gets tracked everywhere, and gets into everything, and so I never use it.
Glad you like the posts. I have learned as more from looking at casting failure photos then from looking at casting successes. With casting failure photos, you can sometimes identify what is causing your problems.
A buddy of mine in Canada asked me to cast a plaque for his UK canal boat.
I needed foundry experience, so I decided to try and cast it in brass.
I had heard about the zinc fume danger when melting brass, so I wore a powered respirator.
Results:
The results were sub-par in my opinion. I consider the plaque with the larger letters a marginal success, and the plaque with the small letters not acceptable quality.
Lots of zinc fumes. This melt sort of cured me of the desire to pour brass.
I build a soft-fire-brick furnace for this small melt, and used propane for fuel.
Anybody who reads all the threads and posts on foundry work that have been put on here will be way ahead of where I started from ! Almost all you need to know is contained here, apply it diligently and you will succeed ! Another valid point Dave ! Noel.
I was about to say you need more practice with the welding, but you sort of beat me to it ! Sand to dry or lacking bond ? You poured on concrete, potentially a fatal mistake !
I like the stainless furnace, I hope you drank the beer first ?
Thanks Dave, I really was about to throw in the towel before I figured out iron.
If it were not for the guy from Australia (goes by the screen name ironsided/luckygen, etc) and another local buddy of mine who started doing iron, I probably would have given up.
This story goes on forever, is the reason I broke it out from the other thread.
Noel-
My welds look bad, but they are solid. I have some really good all-position 6011 rods, and I leave quite a bit of gap so as to get a full penetration weld. I have never had any weld fail, so don't let the looks deceive you.
The slag has not been chipped off the weld yet, is why they look so rough.
My first furnace used a mild steel shell, and they are prone to corrosion, especially if left outdoors.
I should have bought a stainless 55 gallon drum for a shell, but hindsight is 20/20.
All of my foundry equipment is most definitely function over form.
My goal is to repeatedly make perfect iron castings, and since my fabrication time is very limited, I focus on the end product casting.
There was a bit of beer left over in one keg, and it looked and smelled to be drinkable, but I reluctantly poured it out.
It is great to see all these foundry threads. I have long dreamed of roping more folks into this hobby.
It is not necessarily easy, but loads of fun for sure.
I was under the false impression that the sprue and riser had to extend up above the top of the cope, and have since learned that this is not necessary.
My runner/gate system was becoming more refined.
And I discovered commercial foundry sand named OK85, which is a fine dry sand.
I also discovered sodium silicate as a binder, and so the entire mold is bound with sodium silicate.
Results: The results of this attempt were fair, but not great.
I did not use a degasser, and these brass castings tended to have a lot of small gas bubbles in them.
Brass and bronze turned out to be far more difficult than I imagined, and I consider casting good brass/bronze parts much more difficult than casting gray iron.
