Thanks all for the speedy responses.
I already found a MSDS online MichaelG but thanks for the one you provided.
After mopping up the spill I waited a while to see what reaction if any resulted. Seems like the accumulated oil/dust/rust/dirt ingrained in the benchtop simply neutralised the relatively mild acid properties of the flux as no apparent ill effects an hour later. Likewise the concrete floor appeared unharmed as well as the rubber floor mat. Did notice a 'soapy' feel on the skin of my fingers which came in contact with it when mopping up, but that soon disappeared after washing my hands again.
The only tools that came in contact was a pair of side cutters which I washed and then sprayed with light oil.
Assorted bits of metal lying on the bench which were also splashed with flux were washed and left to dry.
Interestingly, I use an old artists flat painbrush about 6mm wide to apply the flux. It never gets washed and after several years the only damage is some slight corrosion of the aluminium ferrule. The timber handle and the bristles seem to have survived fairly well, although the bristles have suffered from applying flux to surfaces already heated by the soldering iron/blowtorch..
I'll see what everything looks like in the morning. Expecting some light surface corrosion on the steel bits but that won't be a problem.
