Hi, I made a 1M long one in my last job, Which had a piece of 100 x100 x 12mm angle and like pgk pgk says, the apex was uppermost so it had a 45 degree backwards fence. The two outside edges were machine back though where it clamped the sheet being folded, so it had just a very small radius for the bend. The angle also had a 30 x 70mm piece of flat bar tack welded inside the angle, which helped it from bowing during folding and a block was welded on each end of the angle for a sloppy 24mm bolt hole for clamping it down, the sloppy hole made for a bit of adjustment for different thickness metal. We could, with a bit of a grunt, bend a piece of 1mm 306 stainless steel, about 800mm wide in it, but it would do ally up to 1.5mm thick the full 1M wide. It was made to be bolted down to a heavy steel bench. Yes you will always get a bit of spring-back, even on a break press.
Regards Nick.
P.S. on reflection, the clamping blocks welded on each end of the angle, were in fact thick oblong box sections.
Edited By Nicholas Farr on 07/08/2021 15:55:29
