I am making a small "backshaft" for my Taig lathe, and am wondering where is the best place to put the bearings. In the pulley with a fixed shaft, or in the bearing block with the pulley fixed to the shaft.
The large pulley is 80mm, the small one 20mm, the shaft is 8mm (or 10mm) steel, and will use a couple of 8 x16 x 5 bearings. Block & pulley will be aluminium. The Pulley profile is for a 3mm Gates belt ( as used on the lathe).
If I mount the pulley firmly on the shaft, I could use the shaft as a mandrel for turning the pulley and ensure concentricity – but I then need to work out how to stop lateral movement of the shaft in the bearing block.
Putting the bearings in the pulley would make it a bit harder to ensure concentricity, but makes lateral positioning easier – small step on the shaft, and a nut or similar on the small pulley side.
Could I ask the the wisdom of the forum for thoughts, ideas or gotcha's before I make yet more scrap.
