Too long, had to split it.
The point of these is to change the heating area from the fire tubes to a radiant type heater at the top of the firebox. I can find no information about the water temperature gradient within the boiler from above the firebox to just behind the tube plate. Whilst the pressure has to be constant, the rate of boiling doesn’t. Imagine a boiler three feet long, the water temperature will quite definitely drop substantially from one end of the fire tubes to the other.
The third flue has a similar stainless tube arrangement but this is a superheater. If a superheater isn’t wanted then can either have all three flues with the secondary circulation heater, or even just two larger flues.
The secondary circulation heaters are in circuit all the time, the superheater is only used when drawing steam from the boiler. The tube plate will need moving backwards to give room for the plumbing.
Another possibility is to fix solid copper bars to the front of the firebox so they run along inside the bottom of the barrel. If of reasonable size, 1/2” or more square, then conduction will give as much heating as the flues they replace would. Similarly a combustion chamber is just a complicated nuisance, enlarge the flues inside the barrel. With the internal secondary circulation system and the much larger flues then should still heat ok. It is all to do with water circulation around the firebox.
If that wasn’t enough, consider the Stefan-Boltzmann law. This is the power lost due to radiation from surfaces at higher temperatures than the environment.
This is power loss in watts = area in sq cm x 5.735.10^-12 Stefan constant x (work temperature ^4 – ambient temperature ^4). The important detail here is that the temperatures are in K, and that they are to the fourth power. This means that at high temperatures the losses are enormous.
To give an example, at 730C, 1000K, and an environment at 27C, 300K, what size plate can just be kept at that temperature with a 10kW gas torch?
10,000 / (5,735E-12.9.919E11) = 10,000 / 5.69 = 1757 sq cm = 42cm sq
So 10kW will maintain a 16” square copper plate at 730C, assuming the coke bed it is resting on is at the same temperature so no loss on the other side.
This of course assumes that 100% of the heat from the gas torch actually heats the plate, in reality it will be somewhat less.
This is why soldering a boiler 24” long is such a struggle. I am still working on using induction heating, also using a 10kW gas radiant heater under the boiler as background heat. Possibility of resistive heating but the high amperage connection is a puzzle.
More importantly it suggests that it would be better to reduce the size of a boiler by 1 cm all round and replace the missing size by insulation. Also that making a taper boiler is a waste of time, fill the taper under the cladding with insulation.
If really keen then can work out the heat flow from an incandescent fire through the firebox walls and what is then available for the water to absorb. If the water gap around the firebox is increased to allow better circulation then the foundation ring could become a source of weakness. Might need to stop using a solid bar and flange instead, give a bit more flexibility.
A firebox for a 3.1/2” loco obviously can be built and works, what needs testing is whether that size fitted in a 5” loco is an improvement, or not, or can’t tell the difference.
Something to think about at the moment?
I quite realise that this isn’t how it has always been done, but I have never seen any of these type of calculations in the magazines and books. The radiant heat loss equation I had seen before, but the real effect of it had never become apparent, it is a killer.
Edited By JasonB on 18/01/2021 11:29:16
