From the comfort of my Armchair I looked up a dozen Aluminium alloy Datasheets and found only one claiming 'good' machinability in sheet form. It's 6082. 3103, 5251 and 6063 are 'average' or 'acceptable'. All the others highligted machinability as 'poor', including 1050. Not a good choice.
Many metals are optimised for purposes other than being machined. Most aluminium alloys are rated 'excellent' for rolling, extrusion, cold working, soldering and welding. Great for window frames and sheet metal work but not meant to be machined. Expect bother.
My limited experience suggests the bother with Aluminium is mostly down to it's squishiness and low melting point. Tearing, smearing, distortion, and a high risk of swarf welding to the tool. Palliatives; high speed, sharp cutter, plenty of paraffin, and clearing swarf aggressively. Also worth experimenting to find the combination of depth of cut and feed rate that produces best results.
HSS vs Carbide – difficult to say. As neither of them can be spun fast enough for this job on a 2500rpm mill, I'd go for the cheaper option, hoping that HSS might be sharper. Mainly though, I don't think Carbide offers any advantage for milling soft Aluminium, and being brittle might cause expensive breakages. It's the gooey material that suggests HSS – milling fibre-glass in same way, I'd recommend carbide.
