CNC Model building board
Home Forums Workshop Techniques CNC Model building board
  • #447702
    Rod Ashton
      @rodashton53132
      Hi – I am looking for advice in respect to CNC cutting some kind of model board with a high rev. 60 deg V cutter, such that I can detail bricks in OO/OH gauge.
      Your advise appreciated.
      Rod Ashton
        @rodashton53132
        #447703
        Tony Pratt 1
          @tonypratt1
          You need to be more specific.
          Tony
          #447705
          John Haine
            @johnhaine32865
            If you mean something like high quality mdf then you could try Valchromat.
            #447726
            Martin Kyte
              @martinkyte99762
              Trespar, or extruded rail to build a frame.
              regards Martin
              #447731
              Rod Ashton
                @rodashton53132
                Gentlemen – Thank you. Just to clarify. I tried cutting in normal MDF but even at 24000 rpm and a medium feed it was tearing out. Had to sand back very carefully with superfine paper avoiding the very shallow mortar grooves. Would like to find some board with a finer surface.
                #447737
                Rod Ashton
                  @rodashton53132
                  Have applied for a sample of Valchromat and contacted Trespar. They are not cheap sadly I am!
                  #447740
                    Thanks for the clarification, Ron
                    [ you have the tools, but you need a suitable board to work with ]
                    It’s a big step-up in price, but Traffolyte or similar would seem to be the obvious choice.
                    https://en.wikipedia.org/wiki/Traffolyte
                    Millions of Signs, Labels and Dog-Tags have been made from it.
                    https://traffolyte.com/traffolyte-sheet-material/
                    Edited By Michael Gilligan on 20/01/2020 10:53:35
                    #447742
                    Martin Kyte
                      @martinkyte99762
                      My apologies for not reading your original post correctly. I though you wanted to build a CNC router and were looking for framing material. You can probably forget trespar for the brick material. It's essentially a modern version of tuffnell and used for Lab benches etc. It's very rigid, can be machined with wood cutting machines and very flat. Ideal for building small machines, router tables etc.
                      regards Martin
                      #447753
                      John Haine
                        @johnhaine32865
                        I've vgot quite a lot of Valchromat bits, black and blue. I could spare some, how much do you need?
                        You might also try this stuff on MDF to seal the surface before milling.  It gets soaked up like rain in the desert into MDF, apply several coats (outside) and allow to dry thoroughly.  Binds the fibres together in a resin matrix.
                        Edited By John Haine on 20/01/2020 11:52:33
                        #447764
                          one of the PU model/tooling boards that are used to make patterns from may be an option and should not be as fluffy as MDF Though you don't say what grade of MDF you used as there are specific ones for routing that have a denser surface layer.
                          This is a pattern cut from PU board
                          Edited By JasonB on 20/01/2020 12:59:00
                          #447767
                          Rod Ashton
                            @rodashton53132
                            Thank you guys. I am exploring all recommended options. John I would need max 10"x12" or anything smaller. The hardener suggestion is very interesting I am obliged to you.
                            #447770
                            Rod Ashton
                              @rodashton53132
                              Seem`s the PU modelling board is minimum 50mm thick. Seeking something around 4/6mm
                              #447780
                              John Haine
                                @johnhaine32865
                                Rod, have PM'd you.
                                #463747
                                vic francis
                                  @vicfrancis
                                  Hi if you can locate someone with a laser engraver, it gave super results when I used one for detailing brickwork and mortar, ok it was in 1/8 scale, but I was able to do the same for loco shed gwr )windows using acrylic , it was also super quick as well … err i even reproduced a few cracked panes … bah vandals! The mortar line is also much finer than vee cutter….
                                  regards vic
