In May last year , I needed to roll some “T” section brass to support the roof of a loco cab.
Not wishing to purchase gear specifically for the job , I made a set up similar to that detailed by Jason , and it worked very well indeed .
As will be seen , a roller with a groove in it was mounted in the milling machine spindle , and a number of roller bearings mounted on the table , slowest speed and reverse at each end .
