Keyway Broaching
Keyway Broaching
Home Forums Workshop Techniques Keyway Broaching
Viewing 25 posts - 1 through 25 (of 37 total)
  • #441757
    FullaFlava
      @fullaflava
      To fit a power feed I’ve had for ages to my mill, I have a need to increase the diameter of the bore of the drive gear and then make a 5mm keyway. The keyway will need to have a length of approx 70mm and the material is brass.
      I’ve never used a keyway broach before and am unsure how much force is required. Do you think ill be able to push one through with the tail stock on my HLV clone?
      FullaFlava
        @fullaflava
        Using a tailstock?
        #441758
        Joseph Noci 1
          @josephnoci1
          I have broached quite a few bosses in aluminium, none as long as 70mm, and it takes a surprising amount of force. I would be reluctant to put that sort of force on the tailstock screw. Also, that load transfers into the tailstock body and lathe bed. I assume you have all the stepwise increment wedges for the broach as well. Whatever method you end up using, ensure that the force on the broad is really square-on and inline – a 5mm broach bends easily! Also, remove and clean out the chips regularly – 70mm is a long way to go!
          Joe
          #441759
            Better to try with the mill's quill or even a drill press though a hydraulic press is preferable.. Though it is a long keyway and you will have a lot of teeth engaged that will take quite a bit of effort and may well clog the gullets of the teeth so you might have to withdraw the broach part way through to clear out the chips.
            #441760
            David George 1
              @davidgeorge1
              You can cut an internal keyway with a square tool in a boring bar. you make a cutting tool like a part off tool just the width of the key you need and then wind the tool forward without moving the spindle taking small cuts perhaps only a few thou at a time till the depth required. it is better if you can cut a groove in the bore previous to cutting the keyway as it gives you something to run into. if you can lock the spindle is good, at least put it in back gear and isolate the motor before starting.
              David
              #441767
              FullaFlava
                @fullaflava
                Thanks for that, I have planed keyways as David described before but was hoping a broach might be easier, which it likely is with the proper tools.
                Im not sure I have enough headroom in the throat of my mill to use the quill, perhaps I could get over the edge of the table provided I can hold the job properly.
                #441778
                Mike Poole
                  @mikepoole82104
                  You will need a guide bush as long as the hole you wish to broach or you will snap the broach.
                  #441779
                  HOWARDT
                    @howardt
                    Can you shorten the key slot as 70 mm is long and a normal broach may not bee able to produce a size slot that length. Looking at the shaft the key could be recut further down. The norm is to create a relief diameter to clear the slot depth just beyond the key seat. Alternative is to create a separate keyed bush and retain it with screws into the longer bush. Just a thought on alternatives.
                    #441795
                    Brian Oldford
                      @brianoldford70365
                      Can you get access to a shaper? They are one of those much undervalued machines well suited to such tasks.
                      #441809
                        Machine tools such as lathes and mills are not presses, which is what you need to force a broach through metal. Don't even try it. You risk damaging your tailstock or mill. Find someone with a hydraulic press or make up something with two lengths of fine threaded rod of stout diameter and two stout steel plates, one to hold the job in place, the other to bear on the broach.
                        #441810
                        Paul Lousick
                          @paullousick59116
                          I broke a small drill press trying to broach a 3mm keyway. So proceed with caution.
                          Paul.
                          #441812
                          Robert Atkinson 2
                            @robertatkinson2
                            A small arbour (arbor?) press is not expensive and a better tool for the job than the lathe or mill. Once you have one you will find it useful for all sorts of jobs. a 1/2 ton one from china starts at about £35 shipped on ebay, with 1 ton "shipped from UK" at under £50.
                            Robert G8RPI.
                            #441814
                              I think you would need at least a 3 ton arbor press to get the height, without going down to the workshop to measure my 3/16" broach is 7-8" long and add to that the 70mm part and you want close to 300mm height to play with. You won't even get the broach into a 1/2ton one!
                              #441815
                              Ron Laden
                                @ronladen17547
                                There is a pre owned 3 ton arbor press on Ebay at the moment £80 which has 300mm of travel.
                                #441818
                                FullaFlava
                                  @fullaflava
                                  Many thanks for the replies and opinions, much as a press seems a good idea, I don’t see a use for one beyond this job (plus having to put it somewhere) and I thought the lathe might be a work around.
                                  A buddy 35 miles away has a 10 tonne hydraulic press, if I get all the shizzle required together, I’ll go and borrow the use of it.
                                  From what I understand, I’ll need the broach, the gear, a full length 70mm steel bushing with a slot, shims which I suppose will also need to be full length and lube.
                                  I’ll also look at the shorter bush as mentioned by Howard T, but I’m not sure there’s enough meat on the diameter to have an insert and be strong enough.
                                  #441822
                                  Alistair Robertson 1
                                    @alistairrobertson1
                                    A push broach will work fine but care is really needed. When we had long bore to keyway we usually made up a sacrificial bush (of the same material!) then drill a hole of the right size through the assembly. This removed most of the material leaving the broach to square things up.
                                    The length of the broach will be the problem and need an extension so what we did was grind the top end of the broach to a diameter then machine the extension piece to fit on to it. This meant everything was in line and we didn't have to juggle and hold bits with a hand under the press ram!
                                    I once broached a steam engine pulley that was about 9 inches long with a 1/2" keyway through an 2 1/8" bore with no problems.
                                    #441824
                                      I don’t have a clue about this power feed device. I just see a pic of a shaft and a part which needs to fit together.
                                      First, which way does that piece fit over the shaft?
                                      How much do you need to enlarge that hole? Doesn't look like a lot.
                                      Perhaps these people giving info on broaching do know of this particular power feed, but personally I would not want to be broaching through that length of material with that width of broach unless the broach was quite a ’deep’ one. I have the facility to press a broach, but have always found an alternative approach … so far.
                                      Howard and Brian, above, offer sensible alternatives, one of which I would adopt. But even if using my hand shaper, I would relieve as much of the unnecessary section before starting to cut.
                                      #441829
                                      Nicholas Farr
                                        @nicholasfarr14254
                                        Hi, I wouldn't think a 5mm Broach wouldn't take too much to push through, however I've never done it in brass and it may be prudent to do more passes than normal by using thinner shims, which are easy enough to make, thinner shims may help stop the Broach digging into the brass, but as I say I've no experience of broaching brass.
                                        Below is a photo I did through a steel pulley 1" thick with a 1/8" Broach with my No. 4 flypress, which was no bother at all.
                                        Headroom is the thing, both my 1/8" and 3/16" Broach's are 6 3/4" long to give you an idea, but the effective height is about 6" above anything I need to broach because they will sit into the bore about 3/4" before the fist cutting edge starts to touch.
                                        Regards Nick.
                                        #441830
                                          Could you even do away with the rather inconvenient long keyway and use instead a dowel pin through the gear and shaft? Make it out of brass and it could be a safety shear pin?
                                          #441832
                                            The other way to ease the load is to push a smaller width broach through first, I have done this several times when I could not be bothered to make the trip to my friend with the hydraulic press, just shim the smaller one so it cuts to the same depth as the larger. Doing it this way I have done 40-50mm long keyways 3/16" wide in cast iron flywheel hubs with just the old Naerok drill press to push them through with.
                                            If on the lathe then using teh carrage to plane the keyway would be my preference to the tailstock but turn a runout groove part way down teh bore then you only need do about 25mm length. These four 3/16" wide ones on the left are all 1" long and in steel just planed with the carrage.
                                            Similar can be done on the mill using it like a slotter, quicker if you have a quill than just a knee.
                                            #441833
                                              Posted by Hopper on 16/12/2019 11:10:03:
                                              star
                                              Now that’s what I call Engineering yes
                                              HOWARDT
                                                @howardt
                                                Just had one thought, you could drill a hole at the end of the required key position and slot into that rather than going all the way through.
                                                #441903
                                                  Or yet another – extend the key slot, on the shaft, right to the end of the shaft and insert a longer key (or the original and make provision to secure it in place) after sliding on the piece.? Only need a short slot in the supplied piece for that, which my hand shaper would cut without too much effort.
                                                  #441909
                                                  FullaFlava
                                                    @fullaflava
                                                    I had another look at it today, nothing is ever as easy as I hope. The box has sat in the corner for years and I’d forgotten all the wrinkles. I will post pics tomorrow as an explanation but more enginerding is required.
                                                    #441920
                                                    Nicholas Farr
                                                      @nicholasfarr14254
                                                      Hi, all very well using a shorter slot for a key, but you have to consider the loading on it. I've seen keys that have been sheared in half by not being long enough for the load they have to carry. Keys are not a passive component and you can observe this when dismantling machinery that have been in service with good fitting disciplines.
                                                      Regards Nick.
