Thread Cutting on Myford Super 7
Home Forums Workshop Techniques Thread Cutting on Myford Super 7
  • #16110
    Tom Gullan
      @tomgullan59234
      Cutting a UN thread
      Tom Gullan
        @tomgullan59234
        Hello,
        I’ve cut quite a few different types of imperial threads on my Myford Super 7B with success however, I now have a problem!
        I’m trying to cut a 1” x 24tpi UN thread… my scratch test is way out! The plate on the gearbox states “For fine feeds reverse gear on stud ‘A’ ”.
        I can’t find stud ‘A’. Can anyone help?
        Tom
        #431171
        Martin Kyte
          @martinkyte99762
          The gear is the one held in place with the 'latch strap' for want of a better word. Open the cover to the gear train and it should be obvious. The black strap just swings out of the way and the gear can be removed and reversed.
          If you have cut threads before you will have had the gear in the correct orientation I should have thought. You don't want fine feeds for thread cutting. Is ther not a picture on th gearbox plate?
          regards Martin
          #431173
          Martin Kyte
            @martinkyte99762
            See
            The strap is item 211 the stud is 206 and the gear is 208
            regards Martin
            #431312
            Brian Wood
              @brianwood45127
              Tom,
              Just to add a bit of detail to Martin's posts. The gear on stud A is a tandem 19/57 tooth compound if that helps you recognise it and as he says, it is reversed on that stud to give fine feeds for normal machining…
              24 tpi is a standard pitch that the gearbox can provide, the middle choice of the set 12/24/48 tpi , just follow the picture on the gearbox plate and set it accordingly.
              Regards Brian
              #431321
              Tom Gullan
                @tomgullan59234
                Brian,
                Thank you, I appreciate your input.
                Tom
                #431323
                Simon Williams 3
                  @simonwilliams3
                  Tom, good morning.
                  24TPI isn't a fine feed within the meaning of the phrase in this circumstance, and you don't need to reverse the 17/57 gear pair on stud A to get it. Reversing this gear gives you the range of fine feeds as marked on the gearbox label, but we're talking about a few thou per rev (13 down to 1) such as you would use in turning a parallel surface.
                  If setting the top lever to centre, and the sliding handle to third from the right doesn't get you 24TPI there is something else wrong. Could you let us know what thread your scratch test showed, maybe we can reverse engineer the cause from the symptoms.
                  Handily my picture happens to be taken from the very angle that lets the top lever obscure the 24TPI setting on the label.
                  What thread have you actually cut, and if it is very fine indeed is the gear on stud A already reversed?
                  Otherwise can we have a picture of the gear train from the mandrel down to the gearbox input gear cos' the explanation's there somewhere.
                  HTH Simon
                  #431325
                  Tom Gullan
                    @tomgullan59234
                    Brian, Simon,
                    I managed to figure out what I was doing wrong. The gear leaver on the top of the gearbox was not engaged in the middle position although it looked as if it was… it was actually cutting 12 tpi instead of 24 tpi.
                    The reason I’m cutting a fine thread is to allow me to screw cylinder liners onto the casing of my Upshur Opposed Twin four Stroke Petrol engine. I only want to start the thread so that the die will run parallel with the liner. I’m not an engineer…. only a keen amateur!! I thought this would be the best way to ensure that the thread was concentric with the bore.
                    Tom
                    #431334
                    Simon Williams 3
                      @simonwilliams3
                      Ah Hah! That'll do it!
                      Many thanks Tom for the update, it's always nice to know how these things resolve themselves.
                      Now we're looking forward to some pictures of the EIP (engine in progress) pretty please
                      Best rgds Simon
                      #431347
                      Emgee
                        @emgee
                        Posted by Tom Gullan on 01/10/2019 10:27:44:
                        Brian, Simon,The reason I’m cutting a fine thread is to allow me to screw cylinder liners onto the casing of my Upshur Opposed Twin four Stroke Petrol engine. I only want to start the thread so that the die will run parallel with the liner.
                        Tom
                        Tom, when you are set-up for threading it may be best to continue the thread for the full length to almost full depth before using the die to clean the crests and roots, your'e sure then of a parallel thread for the full length.
                        Emgee
                        #431371
                        Tom Gullan
                          @tomgullan59234
                          Ember,
                          Thank you.
                          Tom
                          #431375
                          Tom Gullan
                            @tomgullan59234
                            Simon,
                            As requested, here are some photos of my build so far:
                            1. The Petrol tank
                            2. A CAD mock-up of the casing.
                            3. Cylinder head.
                            4. Crankshafts.
                            5. Flywheel 01.
                            6. Cylinder, con-rods, and piston.
                            7. Flywheel 02.
                            8. Cams.
                            9. Carburettor.
