These are some of the extended drills I have accumulated. Most of the extension material I get from rails and guides in discarded ink jet printers and drills or cutter is retained by whatever is convenient at the time. I've used grub screws, press fit, deformed the tube wall into notch or flat.
Longest extension I have made was a 1.5m length of 1/2" diameter steel bar drilled to accept a 16mm wood flat-bit which I used to drill vertically downwards through the various noggins in a studded bedroom wall in order to run wiring to a new light switch without having to do any subsequent redecorating.
Ian P
