Drill Speed
Drill Speed
Home Forums Workshop Techniques Drill Speed
  • #385780
    Vic
      @vic
      What’s the general consensus on this chart?
      Do some of the speeds look a bit too fast for hobbyist equipment? face 7
      Vic
        @vic
        Drill Speed
        #385785
        Ian P
          @ianp
          I can't give you a consensus as I am only one person. Some of the speeds shown are fast, but maybe not too fast to drill the holes in the materials with drills shown, but as you say, some home workshop drilling equipment might not have the highest speeds available.
          IanP
          #385787
          HOWARDT
            @howardt
            Drill speed and diameter are related to feed and torque. Also having the correct cutting profile, point angle etc. As most of us use generic drills on a hand fed machine with little power we find what works by feel,or number of burnt out drills. Plenty of power calculations from the manufacturers if you want to get technical and have a power feed machine.
            #385788
            larry phelan 1
              @larryphelan1
              500 RPM sounds about for 1/2" drill in Mild Steel
              1000 about right for 1/4"
              Works OK in my "Chinese -drill-of-the-day" [drills need to be sharp to cut at any speed ! ]
              #385791
              ega
                @ega
                Vic:
                Thanks for the link to this comprehensive chart.
                Some may see the hole saw recommendations as over-conservative.
                The B&D pilot/bullet point bits are excellent but look difficult to sharpen; I haven't seen them on sale recently.
                #385793
                Vic
                  @vic
                  ega, Yes, I’ve found the Bullet drills to be very good, I’ve even used them as makeshift counterbores. Several companies including Black & Decker and DeWalt sell them.
                  #385803
                  Brian Wood
                    @brianwood45127
                    For interest, I have used holesaws to cut large holes in the region of 2 inch diameter and more in cast iron. Feed gently from the tailstock at chuck speeds of 60 rpm or less if you can get it and once the teeth are fully engaged in the component, withdraw it frequently to clear chips. If it squeals, a little oil will help, more to lubricate the side of the holesaw rather than the teeth.
                    On deep drilling in such sizes cut through from both sides to meet in the middle, using the pilot drill as a guide to setting it up in reverse in the chuck. Keep the plug, it could well prove useful another day.
                    This last point if also helpful in avoiding the snatch on breakthough in any drilling job, meeting somewhere in solid metal is much less traumatic than a grab by the drill flutes.
                    Brian
                    PS Vic I think the speed from the table for the larger drill sizes is to much too high, I suggest half those values; you also need a really solid set up to drill a 1 inch diameter hole with a twist drill; a three cornered hole is often the result as the drill flexes.
                    #385820
                    Vic
                      @vic
                      Well that’s what I though Brian, 1000 rpm for a 1” twist drill in Alloy, I’d be nervous at half that.
                      #385861
                      Zan
                        @zan
                        A 1” drill would need a sizeable machine. Saw a massive scrap radial machine last week. Must have weighed 4 tons, the column was at least 18” diameter. The speed said 75 rpm for a 3” drill
                        Big machine, and serious clamping of the work needed! My of fobco bench drill vas a fitted vdf. Magic ! Well worth the money, never had it on the right speed before, and changing speed was such a faff it stayed on one most of the time. Speeds in general look ok to me
                        Edit. Autocorrect. Fed up with it!
                        Edited By Zan on 15/12/2018 23:56:28
                        #385875
                        Perko7
                          @perko7
                          I can't remember ever changing the speed on my belt-drive bench drill press regardless of what size drill I was using and what type of material I was drilling. I think drills must be very forgiving provided you don't put too much pressure on them and you make sure they are running true and vertical. The only time I've broken one in the drill press is when the workpiece moved causing the drill to bend. Can't say the same for hand-held power drills though indecision.
                          #385886
                          Tony Pratt 1
                            @tonypratt1
                            Posted by Perko7 on 16/12/2018 07:26:24:
                            Not sure if you drive but your drilling practice is akin to always driving your vehicle in one gear, it will sort of go but not to the best of it's ability, costing you both in time, money & frustration.smiley
                            Tony
                            #385890
                            Mick B1
                              @mickb1
                              They look like reasonable guidelines, at least for the twist drills – which I use far more often than any of the others.
                              But guidelines are all they can ever be. Job-specific conditions relating to work- and/or toolholding and/or cooling/lubrication and/or material condition can always introduce issues that might cause you to vary from them.
                              #385900
                              Mike Poole
                                @mikepoole82104
                                It is a useful exercise to make a chart of the maximum size drill bit for each speed of your particular drill and a column for each material you use. Once you have made the chart you will soon remember a lot of the speeds.
