Electroforming voltage question
Home Forums Workshop Techniques Electroforming voltage question
  • #347135
    Jeff Dayman
      @jeffdayman43397
      Question for Mr Wessel – Just read ME 4579 with the electroforming article. Very interesting read. The article mentions current settings but does not seem to mention the voltage used. I do intend to do some electroforming on one of my projects so I'd like to know the voltage. As the article mentions anodes and cathodes (and having fooled around with plating a bit) I expect DC was used although the article did not specifically mention it.
      Looking forward to seeing test runs of the ENV engine. Great work so far on it.
      Thanks JD
      Edited By Jeff Dayman on 22/03/2018 19:58:25
      Edited By Jeff Dayman on 22/03/2018 19:58:35
      Jeff Dayman
        @jeffdayman43397
        #347219
          I visited the people who supply Stephen with his materials (Gateros Plating), I've had some anodising solutions off them (dies and sealer).
          For both anodising and electroplating/forming they said my ordinary car battery charger would be fine.
          It has to be DC. anode is +ve.
          Worth contacting them for advice on plating solutions etc. I was impressed with things they have achieved like brass plating 3D prints!
          Hopefully they will be producing articles on anodising and plating for MEW in the near future. They are also developing courses aimed at model engineers.
            In electroplating it's the flow of current that does the work. The voltage only needs to be high enough to produce the required flow of current. That amount of current depends on the materials, the size of the area being plated, and – within limits – how fast the plating is to be done.
            Generally plating calls for a DC power supply delivering lots of amps at a few volts, perhaps less than 2V. A small amateur set-up would work with a few amps; a big industrial plater could consume thousands. In both cases the voltage will be the same – low. (This is not like motors where a 1000V motor at 1A delivers the same power as a 10V motor at 100A).
            It's important not to over volt whilst plating. Too high a deposition rate will form a spongy layer poorly fixed to the item being plated. Excess voltage will also decompose and heat the electrolyte. A hot gassy electrolyte full of active ions is likely to cause multiple unwanted side-reactions, all reducing the quality of the electroplate whilst wasting power.
            Years ago I looked for and failed to find a suitable and affordable power-supply for electroplating, say variable 0-3VDC at 20 amps+. That was before the internet! Can anyone recommend one now?
            Russell Eberhardt
              @russelleberhardt48058
              If using a variable voltage supply you need to include a series resistor otherwise the current will be too sensitive to changes in temperature, condition of electrodes etc., and you will have to keep adjusting it. Depending on the current you require you could perhaps use an old electric fire element or just part of it.
              Russell
              #347252
              john fletcher 1
                @johnfletcher1
                As already been suggested use an older type car battery charger, the one with a transformer and rectifier. They easily modified to obtain a lower voltages. Being very careful you can wind on another set of windings over the top of the existing set, make tapping at every two volts, then bring the connection onto the front of the steel box/cabinet. A simple way of adjusting the current, an ammeter would be an asset but you can use a multimeter on the DC amp range. As Dave has said to higher rate (amperage) and the deposit is spongy, a bit of trial and error is needed.I copper coated a friends carburettor so that he could have it chromed, it didn't improve the fuel consumption, but he said it looked better. John
                #347255
                  My charger is a 6/12V one with 'high/ low' settings. To be fair it was suggested that this will be ideal for anodising, especially with proper anodising dyes as the pore size is much less critical than when using makeshift colours.
                  A way to manage the current is by reducing the size of the anode. It's not a linear relationship but if things go too fast, one cure is to lift part of it out of the solution.
                  Barnaby Wilde
                    @barnabywilde70941
                    I'm a little bit confused.
                    I contract out a lot of anodising after successfully experimenting with a home setup & I'm still firmly in the belief that anodising is all about controlling the amps. The voltage can vary due to very many factors, but to be in control of the process you need to control the amps.
                    I've discovered for myself, confirmed by my anodiser of choice, that controlling the amps cannot be done with a 6/12v battery charger. There are too many variables that make this power source a hit-n-miss affair. Yes, you can anodise a part with a battery charger . . . But you cannot repeat that result unless you control the multiple variables . . . Which makes being able to control just the amps seem like the sensible choice.
                    Am I confusing anodising with electro-plating?
                    #347283
                      I'm not speaking from experience, but from advice I've been given by people who clearly make it work. I won't try and summarise everything I was told as I will make mistakes, but temperature and anode size seem to be most important and lower amps can be compensated for by longer anodising BUT if you use non-standard dies low amps can lead to tiny pores and poor colouration.
                      That did point out that its a lot easier to match your own work by using a consistent process than to achieve a specific result like professionals do.
                      #347302
                      Jeff Dayman
                        @jeffdayman43397
                        Neil could you please pass on my info request to Mr Wessel? I'm assuming you have his contact info since he contributed the article. I'd simply like to know what voltage he used to get his very successful copper electroforming results as seen in ME 4579, nothing more. The thread's gone way off topic from the original info request. Thanks JD
                        #347314
                        Barnaby Wilde
                          @barnabywilde70941
                          Posted by Jeff Dayman on 23/03/2018 23:15:15:
                          Steven mentions setting the current at about 3amps, giving a current density of about 75mA/sq.inch.
                          In home electroforming, as it is in anodising & electro plating, you need to control the amps. The voltage going in is largely irrelevant, it will fluctuate/rise during the process. It is possible to successfully complete a process using a fixed & constant voltage but this is not practical & is best left to pro's with huge tanks & lots of experience.
                          IME you can monitor the voltage to judge whether the process is going OK & not failed. If I were anodising this part in my tanks at 3amps I would expect the voltage to be in the range of 5-15v & I cannot think of any reason why it would be much different in electroforming.
                          #347331
                          Stephen Wessel 1
                            @stephenwessel1
                            Hello Jeff. Neil drew my attention to this forum post.
                            What you need is a small, cheap power supply. The one I use came from http://www.rcpitstop.co.uk and is called Fusion 200W twin output adjustable, PS201ADJT, cost £35.95. This was the cheapest supplier I could find but the same model is offered elsewhere.
                            In my previous electroforming work I used a 12V battery with various resistances in series (light bulbs etc) to get the current I wanted. The current is your starting point so you must have a ,means of measuring it. I used my multimeter. Then you can use really any source of DC power and it doesn't matter what its nominal voltage is. The Fusion will show you the actual volts & amps and the volts will probably be around 1 to 3 depending on the size of the job.
                            I cannot emphasise enough that getting a Fusion or one like it will remove so many headaches and constant hunts around the shop for resistors and bits of wire, connectors, bad joints etc etc. I found the current remained absolutely stable despite changes of temp for hours on end. OK it's 40 quid but I don't think you would regret it as it removes a kind of mental barrier to all sorts of plating you might want to do in the future. Just plug in and go!
                            You must calculate your current density in advance using the area of the cathode. Industry usually quotes in A/dm (amps per decimetre) but I prefer A/ sq inch. Keep this lower than advised by industry sources, especially if using copper scrap as the anode, to ensure a fine grain smooth deposit. Any sign of nodules means that current should be reduced.
                            Another tip is to stir the electrolyte and avoid air bubblling which creates a fine mist all over the place, corrodes your connectors and depletes the solution.
                            BTW Gateros Plating is a good company, very approachable and friendly. They are writing a book about plating and about to run classes as Neil said. Also they realise that their website and instructions sent out with kits are a bit sparse on info, so are taking steps to improve all this.
                            Good luck with your project
                            Stephen Wessel
                            #347332
                              Posted by Mick Charity on 24/03/2018 07:48:37:
                              I sympathise with Jeff who asked about electro-forming only to learn about anodising! Anodising and electro-forming are different processes. What's best for one isn't good for the other.
                              In anodising an electric current is used to increase the thickness of the surface oxide layer. It is not a metal plating process at all. As it's often wanted to colour the anodised surface it's good to make the oxide layer porous to take a dye. It helps to encourage the porous layer by applying more volts. Compared with electroplating the bad effect of using too many volts is less obvious. Anodising is altogether more tolerant.
                              In electroplating an electric current is used to deposit metal on to a conductive surface. The aim is to deposit a solid layer of pure metal, uncontaminated by oxides, with no pores at all. To do this well requires careful control of the current flowing. Unwanted side-effects are minimised by carefully increasing the voltage from zero until the required current is flowing. Probably between 1.2V and 5V. I expect this is the answer Jeff will get from Mr Wessel.
                              In professional electroplating equally careful attention is paid to the electrolyte. Potassium Cyanide is good if you can get it! It's difficult for amateurs to electroplate as well as a professional because they have all the advantages. Equipment necessary for cleaning, plating tanks with proper electrics, difficult to get chemicals, and a good understanding of electrochemical best-practice. I'm impressed by Mr Wessel's results.
                              Edit: Typical – I press send only to find that Stephen got in first.  I hope his answer doesn't make mine look too foolish!
                              Edited By SillyOldDuffer on 24/03/2018 11:08:57
                              #347335
                                Posted by Stephen Wessel 1 on 24/03/2018 10:40:13:
                                The products I ordered all came with about six pages of detailed manufacturers datasheet, so it looks like they have.
                                Russell Eberhardt
                                  I totally agree with Stephen and S.O.D. It's a matter of basic electrochemistry. The rate of deposition is directly proportional to the current flow. In fact the Ampere was originally defined according to the rate of deposition of silver on the cathode in a silver nitrate bath.
                                  Controlling the voltage only indirectly controls the current.  It is non linear and sensitive to things like temperature.
                                  You need to control the current and thus the deposition rate to get the best surface finish and adhesion.
                                  Russell.
                                  Edited By Russell Eberhardt on 24/03/2018 11:35:48
                                  #347346
                                  Jeff Dayman
                                    @jeffdayman43397
                                    "Hello Jeff. Neil drew my attention to this forum post."
                                    Many thanks Stephen, I appreciate your answer to my question and your advice about the power supply and the techniques you mentioned. I'll make good use of the info in my project. Thanks also to Neil for directing you to my question post. JD
                                    #347347
                                    Jeff Dayman
                                      @jeffdayman43397
                                      duplicate  post in error, sorry
                                      Edited By Jeff Dayman on 24/03/2018 12:05:04
                                      #347354
                                      Ian S C
                                        @iansc
                                        A useful book I have on amateur electro-plating is "Electro-Plating" ,fully illustrated, one of the little "Amateur Mechanic & Work" handbooks, its probably pre WW2, but not too far back, it covers chrome plate.
                                        Ian S C
