Spotting Drill or Centre drill.
Home Forums Workshop Techniques Spotting Drill or Centre drill.
Viewing 25 posts - 1 through 25 (of 51 total)
  • #340587
    Vic
      @vic
      I was watching a Clickspring video on YouTube the other day and noticed that like me he used a spotting drill to start off a hole on the lathe and wondered how many others do this. Or do you use a centre drill instead?
      Edited By Vic on 09/02/2018 12:46:24
      Vic
        @vic
        #340590
          Spotting drill for me all the time in lathe and mill unless I particularly need a ctr hole
          #340591
          FLguy
            @flguy
            Spotting drill. I'd like more sizes than I have too.
            #340594
            Mike Crossfield
              @mikecrossfield92481
              I switched to using a spotting drill a year or two back, and only now use centre drill when I need a 60 degree centre for between centres turning.
              I wish I could find a low cost source however. Spotting drills seem very expensive compared to centre drills.
              #340595
                Five bob each way here. I often use a larger size centre drill but use only the tip of it to put a small divot in the job, as one would do with a spotting drill. This works real well for tiny size drills where if you use the appropriate tiny sized centre drill in wobbly ancient machinery (or is it the wobbly ancient operator?) it is soooo easy to break the tiny tip right off it.
                #340602
                Vic
                  @vic
                  Posted by Mike Crossfield on 09/02/2018 13:18:18:
                  Yes, they do seem a bit expensive don’t they.
                  #340603
                  Mick B1
                    @mickb1
                    I must've led a sheltered life in engineering – I'd never heard of a spot drill before I read this thread.
                    They're eye-wateringly expensive.
                    Although I've occasionally broken centre drill pilots, it's always been when I was impatient to drill the 60 degree cone in something difficult, not when I was spotting to guide a standard twist drill.
                    I think I'll stick with centre drills.
                    #340605
                    Anonymous
                      On the milling machine I rarely use spotting drills and never use centre drills. A 4-facet drill starts accurately enough without needing either. When I do need extra precision, or the surface isn't flat, I use a carbide spot drill to start.
                      On the main lathe I use centre drills; they're way cheaper than carbide spot drills. On the Britan I use LH centre drills.
                      #340606
                      larry Phelan
                        @larryphelan54019
                        To Mike and Vic,
                        Look up a place called "Drills UK",They sell spotting drills,double ended,and not at all dear. I bought some MT drills from them a while back and am quite pleased with them. Along the way,I saw those spotting drills in many different sizes.I bought a pack of 10 5mm stub drills for £4 ,95.,are these what you are looking for?
                        #340607
                          I just use 1/8 and 3/16 spotting drills, I like the Americam made Keo brand as they have the smallest "flat" between the webs that I have found. Don't think £2.42 inc vat from MSC is too bad though they are not stocking them anymore so just some left in the clearance except the 1/8" ones as I just bought their last 4 in stockdevil
                          A lot depends on what I'm drilling like Andrew I will use a split point Dormer straight onto the metal in some cases particularly if I have got the stub length needed and I have most of the common sizes in those.
                          #340609
                          Michael Horner
                            @michaelhorner54327
                            Spotting drill .
                            Usually I'm repairing a shaft by drilling and tapping. Go in deep enough so when I thread it doesn't pull the surface up.
                            1 less operation!
                            Cheers Michael.
                            #340614
                            Vic
                              @vic
                              Posted by larry Phelan on 09/02/2018 14:48:39:
                              To Mike and Vic,
                              I’m not looking for any at the moment as I have 6, 8 & 10mm spotting drills. They are not the same as stub drills.
                              #340615
                              MW
                                @mw27036
                                I pretty much use centre drills for everything, but for some very soft materials I don't even bother as there's pretty much no resistance to the point when it goes in, provided it's a split point drill.
                                I honestly was never shown spotting drills when training and only discovered them through youtube and watching others on the forum, so i'll have to check them out one day.
                                Michael W
                                Edited By Michael-w on 09/02/2018 15:46:50
                                #340616
                                Tony Pratt 1
                                  @tonypratt1
                                  Spotting drills
                                  Tony
                                  #340617
                                  SteveI
                                    @stevei
                                    For the folks using spotting drills are these 90 degree or 120 degree or another angle? I assume you follow up with a 118 degree or as near as regular twist drill.
                                    Thanks,
                                    Steve
                                    #340619
                                      I just use the 90deg ones as they can give the hole a chamfer at the same time and as Michael says if tapping that little chamfer stops the area around the hole being raised up particularly if tapping softer metals. Regular angled drill follows OK.
                                      #340632
                                      larry Phelan
                                        @larryphelan54019
                                        Sorry about that Vic,my mistake. I still have a lot to learn. I will look into that,I dont think I ever came across spotting drills but I did hear of stub drills,and I thought they were one and the same. I live and learn !
                                        #340635
                                        Tomfilery
                                          @tomfilery
                                          90 degree spotting drill for me too!
                                          I mostly use a 3mm one, even for tiny holes, and follow up with a normal 118 degree drill.
                                          Tom
                                          #340639
                                            All mine (which are in small sizes up to 3mm, came with those rotary tool accessory sets that contain lots of useful consumables and a few weird tips
                                            Mick B1
                                              @mickb1
                                              To Mike and Vic,
                                              Nah, still sticking to centre drills.
                                              Those folk don't seem to be offering spotting drills unless they're the same as 'spot weld' drills – not double-ended either. Cromwell's spot drills seem to be around a tenner each, and they're not double-ended either.
                                              Centre drill don't have cylindrical land and cut on the side as well as the point, so any eccentricity gets taken out. I've sometimes succesfully used the pilot as a tiny slot drill.
                                              I can't see any substantial advantage in the spotting drill that's worth its price differential.
                                              #340664
                                              Vic
                                                @vic
                                                I made a small turned part some years back and the hole ended up off centre when I used a centre drill to start the hole. I switched to using a spotting drill on the replacement part and I’ve used them ever since. I wouldn’t be without one or two now although I still use centre drills when needed. I’ve settled on using an 8mm on most jobs for some reason. Unlike centre drills you can’t snap the tip off so I’ve not needed to replace any yet.
                                                #340688
                                                Nick Hulme
                                                  @nickhulme30114
                                                  Centre drills in the lathe, spotting drills on the mill if required (sometimes spot a layout to finish on the mill drill or drill press.
                                                  My centre drills have always self centred perfectly on the lathe, I can't imagine a way to stuff that up
                                                  #340693
                                                  Fowlers Fury
                                                    @fowlersfury
                                                    Assuming there's no 'pip' left on the piece in the chuck and you are using a centre drill which either doesn't centre correctly or the tip breaks, there are several causes. One is a worn tailstock barrel. Another, peculiar to Myfords (only?), is that the hole in the back of the tailstock barrel into which that small, round dowel with its key fits, has become distorted. This can cause the barrel to "twitch" when you start drilling. Geo Thomas published a remedy in the M.E. some years ago. [I think it's also included in his Model Engineers Workshop Manual Vol 1].
                                                    When done on my original & well-worn Super 7, it cured the breaking of centre drill points.
                                                    #340697
                                                    Muzzer
                                                      @muzzer
                                                      If you suffer from the problem of the loose / wobbly tailstock, centre drills are a risky proposition, so a spotting drill would be a good solution. The reason there is a small (brittle) drill on a centre drill is to give clearance for the point of the centre. One simple solution would be to use a spotting drill and grind off the very end of the centre. Pragmatic.
                                                      Murray
