Posted by Circlip on 10/10/2017 12:43:33:
Posted by Ian S C on 10/10/2017 12:04:56:
The rest of it looks a little stuffed, but the fan is not beyond redemption, I had a similar problem with a pulley. I bored the hole out to round, made a new hub, and used half a dozen 1/4" UNF cap screws to fix the two parts together.
Don't suppose the crack from the "bore" to the outer edge will help much. Adaptor would need to be like a chuck backplate.
It may turn out to be a fool's errand, but I am optimistic about returning this pump to service.
After initially discovering water/silt filling the motor housing, I imagined the pump was a lost cause. While able to scrape and brush silt from the case and windings, the endbell contents were not accessible with the armature held in place by the fan. Feeling there was nothing to lose, the endbell was simply rinsed out w/ tap water – a lot of debris flushed away. A nod to propriety called for a brief effort to oil the bearings. Then the motor was buttoned back up and powered.
To my surprise the motor ran on a 10A fuse, despite being fitted w/ a 60A in service. Sounded like a blender full of raw carrots, mind you.
It was tempting to leave well enough alone, maybe just change out the bottom bearing. After all, the thing seldom ever runs, not for long when it does and the bearing in the endbell might not be too bad, right? But where's the fun in being pragmatic …
Ian S C and Circlip's suggestions regarding fan repair by attaching this to a bespoke hub align with my thinking. As supplied, the fan disk (between hub/blades) has a close fit within the circumference, top & bottom of the scroll housing – some modification will be in order.
If I had whiter teeth, fresher breath and a more engaging personality, perhaps I could persuade a fellow member of a local club who EDM'd compressor blades for his scale turbine to similarly make a replica of my factory part. Alas, I expect to be found wanting on all counts.
