Posted by Peter Maloney on 30/07/2017 15:31:49:
I too have thought about cylindrical die blocks but have been concerned about lack of surface area contact and subsequent increased wear. Do you use steel or bronze for the cylindrical die blocks? I suppose that with the relatively little use the models get, that the blocks will last some time.
Well done, a tricky item to make.
I believe that the supplier of castings for my traction engines uses cylindrical bronze dieblocks for the complete engines he builds for sale. Likewise I'd be concerned about wear on what is essentially a line contact, as the loads can be quite high. In theory the harder materiial can wear first, so using bronze seems the wrong way round.
I've only ever made one set of expansion links, for a fellow builder rather than for my engines, and I cheated by using a CNC mill:
![expansion link me.jpg expansion link me.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
For scale the material is ½" thick gauge plate. I still did a lot of hand filing to get a good fit though. The outside profile was left rough for the recipient to finish. The inner slot was left undersize from the mill and draw filed to fit, using a Hoffmann roller as a guide. The dieblock was left oversize and likewise finished by draw filing to fir the slot. These are Hoffmann rollers, in this case bought on Ebay at an advantageous price:
![hoffmann rollers.jpg hoffmann rollers.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Despite the optical illusion height and diameter are the same.
