Posted by Raymond Anderson on 04/09/2016 18:31:49:
Nick, Have to disagree there. They were originally designed for toolholding, more specifically Drills / reamers. I use them for a lot of workholding as do many others and they are great , but workholding is not what they were designed for. There are far better collets than ER for workholding. even as a milling chuck they are far from the best , they are super at taking axial loads, but not at their strongest with Radial loads. I like them but am not blind to their shortcomings.
cheers
Sorry Raymond but how do you work out that a collet tightened up onto work one side and two tapers the other side cannot accept radial loads ?
Surely the limitation will be the collet holder or machine bearings and as Neil has pointed out milling loads in the axial plane are far higher.
I do so hope this is not one of those urban legends that gets repeated over and over with no fact.
Edited By JasonB on 05/09/2016 12:46:07
