Perhaps I'm missing something or being dense (probably) but how the hell can a 4MT fitting on a test bar be 1.5 inches too long to go into a 4MT socket in the end of a lathe spindle. The small end of 4MT is only 20 thou in. bigger than the 1 inch bore. The only way I can see a standard 4MT male being too long is if the lathe has a "stub" MT taper in it, and since the bore is 1 inch there wouldn't be any point in machining a short taper and then having a step.
I'm confused!
Just read the post above and I'm amazed that Myford would build the lathe that way.
Edited By Keith Long on 18/01/2016 19:52:21
