I know quite a number on here cast their own stuff and I also know quite a few people would like to try it but don't know how or where to get the materials.
I needed to do a bit of casting today so I thought I would do a bit of a pictoral "How To". Casting is not for everybody and to be honest, you only need to do this a couple of times to realise those expensive castings may not be so expensive after all. In fact they may be a bit of a bargain.
Materials. You are going to need some "stuff". Whilst most Casting "stuff" is as old as the hills you are going to need some simple, but basic ingredients. First off, you need the Metal itself. I assume you are going to use Aluminium and old castings along with a bit of good ally material in the form of offcuts will be fine. Then you need a crucible. For casting Ally this could be one of those stainless containers from the supermarket, but don't expect this to last too long, a couple of pours at most is the general experience. I don't know, I have never tried it. I have a couple of good crucibles.
Then you are going to need a Flux and a degassing agent. You can't really go far without these two basic chemicals. I suppose you could possibly use Borax but again I have not tried this. I buy my flux and de-gassing tablets from John Winter Foundry supplies who are one of the shopping partners on this site. They cater especially for the home foundry in one department and also they are the only supplier I know of who supply Oiled Green Sand. I prefer oiled sand as it gives good definition, holds together well, stores well and al the other good things you want. Doesn't come out of carpets easily though as it tends to stick, being oiled an all. You have been warned
Outside everything else, the most indispensable piece of kit you need are a pair of leather gauntlets. You might get away with a pair of gardening gloves. You probably won't. A pair of good gauntlets are not that expensive. Shop around but believe me, you don't want to be cutting corners. Then you are going to need a furnace, I made my own, pair of good tongs for the crucible, I made my own, a drag and cope (the two halves of the mold former, again – I made my own. In fact you can make everything you need yourself if you so wished.
So, let's get on with it, first up, fill the bottom bit with sand:
Then place your pattern in it. I am doing this a bit ass backwards, because I made a simple pattern from a piece of pipe in one piece. A quick look on Utube will show you how it all goes together with a split pattern but this job is in no way precision casting because today I am making Lead Hammers. Close enough is good enough.
The white powder you see sprinkled everywhere is plain old Talcum Powder. Fruits of the Valley I think this was, smelled nice anyway:
There you go, pulled the two apart and now laid the shaft ready in the drag, the bottom part of the mould. I have also now made the runners for pouring the metal in the Cope, the top part of the mold:
Edited By Oompa Lumpa on 07/09/2014 22:57:33
