New Lathe leveling
New Lathe leveling
Home Forums Workshop Techniques New Lathe leveling
Viewing 25 posts - 1 through 25 (of 45 total)
  • #144702
    Terence Yates 1
      @terenceyates1
      I have just taken delivery of a Toolco 1130GV lathe. Similar to the Warco 280VF except it has a 38mm clearance through the headstock. It is held down with four bolts on the head stock and two bolts at the tail stock. How would I go about leveling?
      Terence Yates 1
        @terenceyates1
        #144705
        Gary Wooding
          @garywooding25363
          The objective in levelling is to ensure that the lathe bed is not twisted; if the bed is twisted then everything you cut on the lathe will be tapered to some extent.
          Perhaps the easiest way is by the use of a precision level. You place the level, at right angles to the bed, somewhere convenient on the saddle which you then carefully move from one end of the bed to the other while observing the bubble. There is no requirement to centralise the level, but you must ensure that it doesn't vary along the bed. Any movement in the bubble indicates a twisted bed. You adjust the bolts and or shims until you are satisfied.
          Unfortunately, precision levels are not exactly cheap, and are not needed very often, so its probably best to borrow one if you can.
          There are methods that don't need a precision level, but they are not so straightforward.
          #144708
          NJH
            @njh
            Lots of information out there and a subject that has been discussed here a few times. One snag with this forum however is that I find it very difficult to look back through old threads for information. So ..I did an internet search and quickly found some info.
            For a starter then click HERE and/ or HERE
            Good luck!
            Norman
            #144709
            MattK
              @mattk47317
              This has been covered a number of times. When I have done it I have turned a test bar and measured the diameters at each end. Google "Rollies Dads method" for a way to do this with a minimum of kit or look at Harold Hall's site who explains how he does this. I used both these methods and got good results.
              #144722
              DMB
                @dmb
                I recollect seeing piccy + text somewhere, of a novel method which I wish I could find again to study it and decide on its accuracy. It was I think an arrangement of wood base on lathe bed with an upright of timber securely fixed to base and a string-and-weight secured to the top of the upright. Obviously, the greater the height of pendulum suspension the more sensitive this would be. Cannot understand why I have not seen any mention of this recently. I dont think it was in a book or mag. Does anyone else recall seeing this on this or another forum?
                #144729
                Gary Wooding
                  @garywooding25363
                  The divisions on a typical precision precision level are marked as 0.05mm/mtr. or 0.0005"/10". A plumb bob displacement of 0.5mm (which is about as accurate as you could hope to be) would need a suspension string about 10mtrs long for equivalent accuracy.
                  #144732
                  maurice bennie
                    @mauricebennie99556
                    Hi DMB I have a "plum bob" or is it plomb bob of my grandfather .It is a plank of wood 3ft x4"x3/4" a 2" hole at each end ,joined by a 1/2" slot. string fastened inside the hole opposite the slot ( slot is parallel to outer edge of plank) in the hole at other end ,a lump of lead hangs on string .When plank is held against wall it will show if it is upright Easy to make and easier to see than a spirit level. Sorry I cannot give you a picture camera bust.
                    Hope you can understand my description. Maurice
                    #144735
                    Ian S C
                      @iansc
                      Maurice, you could make a modern version from a bit of box section aluminium extrusion. Ian S C
                      #144737
                      Philrob27
                        @philrob27
                        If you have a iphone/Ipad down load the free Clinometer app from I store did the job when I set up my lathe.
                        #144739
                        Ex contributor
                          @mgnbuk
                          £50 delivered for a 200mm 0.02/M level on Ebay (291067274469)
                          Or for £55 delivered a 150mm box level (271385670211) – will be more useful when you get a milling machine.
                          Neither are that expensive when compared with a new machine.
                          If "Rollies Dad's Method" is so great, why does industry use levels ?
                          Nigel B.
                          #144751
                          Gary Wooding
                            @garywooding25363
                            The Android/IOS clinometer apps I've looked at imply a resolution of 0.1 degrees, which corresponds to approx. 1.75mm/mtr. Not really precision, or am I looking at the wrong apps?
                            #144852
                            Terence Yates 1
                              @terenceyates1
                              Thanks all, I have a suitable level and I set up my ML7 with it's leveling screws with no problem at all. It is just that this lathe has 4 bolting holes on the headstock itself. All in close proximency to each other with the tail stock mounting much further away. I think, what I am trying to say is does it 6 adjuster bolts?
                              Terry
                              #144856
                              Terence Yates 1
                                @terenceyates1
                                Jason B, you have a Warco 280, how did you do yours?
                                Terry.
                                #144858
                                  Terry,
                                  Looking at the photo , it doesn't really appear that they had levelling in mind.
                                  The headstock, with a bolt at each corner shouln't move far, and the support at the tailstock end [despite having only two bolts] has an uncommonly large footprint.
                                  … Sorry, that doesn't really help; it's just an observation.
                                  John Hewes
                                    @johnhewes50816
                                    Hi, this is timely for me as I am just about to reinstall my Boxford, and want to do it properly this time.
                                    I don't have a precision level and was wondering if anyone in or around N.E.Northants (I live near Thrapston), has one they would be prepared to lend me to help out.
                                    I'd be happy to leave a deposit and would only need it for a couple of days.
                                    Fingers crossed,
                                    Kind regards
                                    Thor 🇳🇴
                                      @thor
                                      Hi Terry,
                                      I have a 290 lathe and used two 15mm thick steel plates with holes for bolting to the bottom of the headstock and tailstock. At front end rear end I drilled a hole and tapped MF 14 x 1 and made four leveling screws.
                                      The first photo shows a sketch (not my lathe, just to illustrate the idea):
                                      Here are a couple of photos from my 290F lathe:
                                      The height adjustment is done with a suitable spanner underneath the grey steel plate – the head of the leveling screw is underneath the steel plate and has a square head.
                                      I drilled 8mm dia. holes through the leveling screws and use M8 bolts to tighten them down after adjustment.
                                      Thor
                                      Edited By Thor on 24/02/2014 05:55:55
                                      #144901
                                        If you have 4 bolts at the headstock end you just tighten them down first to something flat and do all the adjustment at the tailstock end. Unless you are bolting the headstock to a random lump of stone that is far from flat you will not be applying any twist or distortion there. If in doubt check under each headstock hole before bolting with a feeler gauge and shim with drinks can. Remember you are not adjusting for 'level' as in surface of a pond but 'no twist' in the bed. So it doesn't matter if if the headstock starts off not perfectlly level.
                                        #144903
                                        MICHAEL WILLIAMS
                                          @michaelwilliams41215
                                          Do you all want to know a secret ???
                                          The majority of small and medium sized lathes delivered to industry are just plonked on the concrete floor and put into immediate use . The more conscientious types might try a feeler under each leg to see if theres a bad contact anywhere – in which case they will either adjust or jam in a bit of sheet . Recorded instances of lathes not performing to spec as delivered – nil .
                                          Edited By MICHAEL WILLIAMS on 24/02/2014 09:13:52
                                          #144906
                                          Douglas Johnston
                                            @douglasjohnston98463
                                            With all the fancy electronic stuff available these days it would be great if someone could come up with a cheap level with high repeatable resolution. For setting up a lathe or mill one would only need a range of a few degrees and this might make the construction easier. I have one of the square electronic levels that cost about £20 and find it useful at times but the resolution is not good enopugh for this task.
                                            Doug
                                            #144908
                                            MICHAEL WILLIAMS
                                              Lathe beds coming from better class makers are usually supplied in neutral stress + neutral distortion condition .
                                              That is in their free form without any inputted strains they are undistorted and perfectly true .
                                              Also not quite all but most lathe beds have a true surface on the underside such that if laid on a surface plate the top surface of bed would be true and the bed stress neutral .
                                              With a four bolt bed support system a person with some sensitivity can set up a new smaller lathe by feel – just adjust each of the supports to a condition of uniform feel on each one .
                                              The note on industrial lathes above does not suggest sloppy working .
                                              Experience has shown that most lathes perform well straight out of the box . Any problems would in any case show up immediately in crooked work and remedies could be applied .
                                              Situation is different on lathes and other machines with long beds and especially with sectional beds – these have to have special treatment during installation .
                                              Michael Williams .
                                              Edited By MICHAEL WILLIAMS on 24/02/2014 09:47:53
                                              #144909
                                              MICHAEL WILLIAMS
                                                Hi Doug ,
                                                Laser pen + mirror + wall + bit of DIY will do it .
                                                Regards ,
                                                Michael Williams .
                                                #144913
                                                  Posted by Bazyle on 24/02/2014 09:01:42:
                                                  Bazyle,
                                                  I think we're on the same wavelength [see my earlier comment]
                                                  Your approach seems entirely reasonable, with one small caveat; When the headstock end is first bolted-down, there needs to be a small gap under the foot at the tailstock end [otherwise the bed might already be being stressed].
                                                  If it were mine, I would first insert a thin spacer [a piece of Gauge Plate with four clearance holes] under the headstock.
                                                  Gary Wooding
                                                    @garywooding25363
                                                    Yak,
                                                    It's not necessary to level both ends of the lathe – it's sufficient to adjust one end (choose the easiest) so that it matches the other. A lathe doesn't need to be actually level – lathes on ships can't be level, but they work OK because they have no twist in the bed.
                                                    If the headstock end is the most difficult to adjust, run the carriage up the headstock and place the level on it. Move the carriage towards the tailstock and watch the level. If it moves more than you like, adjust the tailstock end to compensate. When the bubble movement is acceptable, tighten the bolts and check again. If it's still OK, you're done. You're not seeking to level the bubble, you're only trying to make it the same all along the bed.
                                                    #144921
                                                    MICHAEL WILLIAMS
                                                      A machine bed can in principle have twist , sagging/hogging or lateral distortion in it .
                                                      If bed has multiple mounting points then each section between mountings can have different combinations of the various types of distortion .
                                                      Beds can of course in principle have cross section variation errors as well .
                                                      If any of you are going to ‘ level ‘ a lathe fully then you have to check EVERYTHING .
                                                      OR
                                                      You can reasonably assume that manufacturer made a good job of the bed and that it has no intrinsic faults and set it up in a very simple way .
                                                      Bit different with a used lathe with bed in unknown condition . Oft advocated procedures of correcting problems by twisting lathe bed cause more troubles than they solve . A used lathe bed has to be accepted ‘ as is ‘ and make the best of it OR corrected by grinding or scraping and then set up properly as for a new bed .
                                                      Michael Williams .
