Slitting saw advice
Slitting saw advice
Home Forums Workshop Techniques Slitting saw advice
Viewing 25 posts - 1 through 25 (of 47 total)
  • #138902
    Bob Perkins
      @bobperkins67044
      I'm getting on with my Stuart 10V, and finding Andrew Smiths book invaluable. However the detail on the Conrod is a bit thin. His instructions are to "cut through the middle, either with a miniature hacksaw or a circular slitting saw". A google hunt for a miniature hacksaw throws up nothing helpful, so time to have a go with a slitting saw which is something new to me. I'm planing to use my SX2 mill, and plan to buy an R8 arbour that will hold a range of centres from 1/2" to 1" . My thinking is that this will be nice and rigid. Some advice on the following would be welcome:
      I'm planning to buy a 3" 1/32" thick saw , or is it better to use the smallest diameter I can get away with?
      should I saw the Conrod from the face or the edge?
      fine or coarse teeth?
      is there such a thing as a miniature hacksaw?
      Thanks in advance.
      Bob..
      Bob Perkins
        @bobperkins67044
        #138903
          Thats the valve rod casting!!
          By minature hacksaw he probably means a junior hacksaw which would give a narrower kerf than a standard hacksaw.
          The thinner slitting saw blades can wander a bit if you are not careful, run them at your mills slowest speed and use some cutting fluid even with bronze.
          I would cut it from te end but have the teeth in contact come across the work at about 45degrees, much the same as this
          Edited By JasonB on 27/12/2013 20:29:08
          #138906
          donkey
            @donkey
            Bob do a google search for junior hacksaw. That will find your miniature saw.
            Brian
            #138911
            Harold Hall 1
              @haroldhall1
              Have a look Bob at picture 53 here **LINK**
              Harold
              #138931
              Ian S C
                @iansc
                I'v got a power hacksaw that is powered by a small Stirling Engine, It uses junior hacksaw blades, and has been used to split big ends. It does a lovely job, your big end would take about 15 min, but that's not bad on a bit over 5 Watts. Ian S CRoss Yoke motor
                #138932
                Anonymous
                  I tried one of those multisize slitting saw arbors in a R8 taper: basically useless as it didn't hold the saw anything like concentric or perpendicular to the axis. It went in the bin.
                  Even thick saws (>1/16" ) are prone to go walkies with any depth of cut on a single ended arbor. So I'd use the smallest diameter saw possible. I'd also go for coarse teeth. Fine tooth saws are ok for slotting screw heads but not much use for anything else, as the gullets get clogged.
                  If at all possible I use slitting saws on the horizontal mill. That's what I call rigid wink 2 and I'll happily take cuts up to 15mm deep in one pass.
                  For the job in hand I'd use a junior hacksaw.
                  Edited By Andrew Johnston on 28/12/2013 11:22:46
                  #138937
                  old Al
                    @oldal
                    The design should leave lots of spare metal for a junior hacksaw cut. Just make sure you are using the correct casting
                    #138938
                    speelwerk
                      @speelwerk
                      I have no experience with these type of parts, but making an accurate long cut with a (junior)hacksaw is not something I am succesful in, if it needs to be reasonable accurate a slitting saw is the way to go. Niko.
                      #138940
                      roy entwistle
                        @royentwistle24699
                        Put the casting in a good vice or use packing with the line to be cut just proud of the jaws and then saw using the vice jaws or packing to keep your saw straight ie saw with the blade in touch with the jaws
                        Roy
                        #138942
                          I've never had much success with those wavy blades that are usually fitted to Junior Hacksaws. Does anyone sell a high-quality straight blade for jobs like this ??
                          John Stevenson 1
                            @johnstevenson1
                            I'm with Andrew on these arbors, there isn't enough support to do a proper job.
                            I know is using tools to make tools but a decent home made arbor is not that much rocket science. Also make a series of support washers of different diameters.
                            You only need enough saw showing to do the job, if the rest is sandwiched between two decent washers it supports the saw and helps get a straight cut.
                            In Art Fenarty's Gearotic program it was originally coded to cut a spur gear using a normal end mill by making repeated passes whilst moving the blank over and dropping the tool so it cut a series of flanks. basically a poor man's Sunderland planer.
                            Biggest problem was on small gears it needed small cutters which as every ham fisted bloke knows are fragile.
                            I got Art to give the facility to cut on the side as opposed to the top using slitting saws. Problem there though is a very fine saw say 10 thou wide will cut a slot but won't want to do a side trimming cut, just deflect off the path.
                            In tests I was using a 10 thou saw with cheek plate washers that allowed just 40 thou of tooth to show and this was then able to side cut a 64 DP gear
                            #139008
                            Bob Perkins
                              @bobperkins67044
                              Thanks for the comments. At present I'm working on the bed and frame castings, and am looking forward in the guide book making a tool shopping list. I haven't spent much time looking at the other components yet, just picking out tap and reamer sizes etc. I think I may cancel the R8 arbour plan and make a mandrill specifically for the slitting saw I buy to fit one of my larger taper collets. I'll figure out the smallest diameter saw I can get away with and as course as possible. Take it steady seems to be the order of the day.
                              Bob..
                              #139009
                              Ian S C
                                @iansc
                                Bob, if you use a junior hacksaw, don't put much weight on it, the more strokes it takes to cut the metal the finer the finish of the cut surface, that's what happens with my little power hacksaw. If the cut goes through at a slight angle to the vertical, don't worry, as long as the cap is assembled the same way each time it will fit perfectly.
                                Ian S C
                                #139018
                                magpie
                                  @magpie
                                  Hi Bob. Don't forget to drill taping size holes in the casting BEFORE you cut. Hope I am not teaching my granny to suck eggs here.
                                  Cheers Derek.
                                  #139101
                                  Ian S C
                                    @iansc
                                    You might find a suitable saw among the Dremel tooling, worth a look. Ian S C
                                    #139114
                                    Sub Mandrel
                                      @submandrel
                                      FWIW I cut the eccentric strap for my 10V with a junior hacksaw as the only slitting saw I had at the time was 1/16" thick. There is plenty of metal for cleaning up the cut surfaces, even if a thin slitting saw wanders a bit.
                                      Bob Perkins
                                        @bobperkins67044
                                        Thanks for the advice all.
                                        #139160
                                          You could use a jewlers saw also available from a popular modellers' knife supplier. Will work on brass though it may seem cruel but even if you blunt the blade it is a minor 'consumable' cost. Don't try it on steel or especially piano wire – that is what the junior hacksaw excells at. Sometimes available at the ME and Ally Pally show on the shesto or other small tools stands. Also available from model railway shops and exhibitions.
                                          #139188
                                          Muzzer
                                            @muzzer
                                            Presumably it doesn't much matter how you cut the thing as long as you don't make a complete arse of it. You will need to bore the central bearing afterwards anyway, so you could easily skim both sawn faces in the milling machine which would be a very simple task and give a clean mating pair. As suggested, it may make sense to drill (and tap) the bolt holes beforehand. Once bolted back together, you can bore out the centre and Bob's your auntie.
                                            #139207
                                            Ian S C
                                              @iansc
                                              When I make a con rod for one of my Stirling Engines, I drill the big end to take a bit of bronze for the bearing, and drill that under size, and drill the bolt holes tapping size, then I cut the bearing, drill the cap holes to size, and tap the big end, and fit the studs, now bore, or ream the bearing, the outside will be oval, and will stop the bearing from moving in the big end. If you like, a bit of Loctite will stop the bronze falling out. This works on any metal used ie., steel, aluminium, what ever. For a 10 mm/3/8" bearing, and above, an ordinary hacksaw/ band saw is OK.
                                              Ian S C
                                              #139402
                                              Sub Mandrel
                                                @submandrel
                                                I vaguely recall only slitting one side of the eccentric, so it could be tightened up to compensate for wear (as if it will ever be run for THAT long!) I'll go and check…
                                                …indeed that IS what I did. The cut is dead square and very neat – I am totally bewildered how I could have made such a good job of it without a very thin slitting saw. I can only think I used a razor saw and ran it along the top of the vice?
                                                If only the rest of the thing was as well made – it was my first 'proper' attempt at model engineering!
                                                stan pearson 1
                                                  @stanpearson1
                                                  Hi Bob
                                                  You should not have a problem with slitting saws, i use all sizes down to 1/64" its the same as useing a hacksaw dont force it let it cut itself and you wont have any trouble. You need to drill the bolt holes first then saw all the way through bolt it back together and then bore the hole to fit crank.
                                                  Stan
                                                  #144229
                                                  Tim Stevens
                                                    @timstevens64731
                                                    The usual name for a 'jeweller's saw' is 'piercing saw'. The standard arrangement arranges the teeth pointing to the handle, so you cut on the pull stroke (like Japanese joinery). This breaks fewer blades. Blades of a wide range of thicknesses and tooth pitch are available – but for this sort of job use the coarsest you can get. Just key 'piercing saw' into E-bay and you will get a selection of saw frames and blades.
                                                    But I expect you have finished the job by now …
                                                    Cheers, Tim
                                                    #144240
                                                    GarryC
                                                      @garryc
                                                      Hi Bob
                                                      This from a complete novice's point of view – slitting saws strike me as potentially being one of the most dangerous pieces of equipment I have come across in Model Engineering should anything go wrong, I've only tried it a couple of times (although without any problems I should say) and is the only activity I have come across when full face protection screams out at you or me anyway! Definitely go slowly I would say – just something to think about…
                                                      Cheers.
                                                      Allan.
                                                      Edited By Allan. on 17/02/2014 16:52:42
