Hand test pump design
Home Forums Workshop Techniques Hand test pump design
  • #15643
    michael cole
      @michaelcole91146
      michael cole
        @michaelcole91146
        Hi
        I need a test pump for a boiler test, around 5 inch gauge loco size. Has anyone got a good design for a pump that I could make in a day or so. I have all the normal tools one would expect.
        Cheers
        #121345
        MICHAEL WILLIAMS
          @michaelwilliams41215
          Hi Michael ,
          Really any side tank or tender pump for a 5 inch gauge engine would serve . There have been many good and bad designs published but most of them basically functioned .
          MikeW
          #121369
          michael cole
            @michaelcole91146
            Thanks MikwW
            But what are the good designs, what makes a good pump. I would like to spend my time makeing a good design then a bad design.
            #121375
            IanT
              @iant
              I'm in the process of building a boiler test rig Mike, although it's not quite finished. I generally based my pump on the design published in EIM May/June 2009. I modified it to use what I had available (brass pump body, aliminium block and stainless steel handle & ram ect. It uses O rings in the valves rather than trying to seat a stainless ball effectively. I found it easy to size the pump to suit the materials to hand and apart from my time – it's cost me nothing. Regards, IanT
              #121413
              michael cole
                @michaelcole91146
                thanks Ian
                Do you know of any online plans ?
                #121527
                MICHAEL WILLIAMS
                  Michael ,
                  I've made several attempts to upload a drawing and article for you relating to a quite nice handpump but on each occasion this site's software has lost interest part way through transmission and locked up .
                  Send me an Email address via pm's and I'll send direct if you still want it ..
                  Michael .
                  #121538
                  VC
                    @vc44480
                    Was going to have a go at testing my own boiler, Got hold of a motorcycle front brake master cylinder. But like a lot of my "projects" thats as far as I got.
                    #121554
                    MICHAEL WILLIAMS
                      MikeC – Emails on way to you (2) .
                      #121589
                      michael cole
                        @michaelcole91146
                        thanks Mike
