3D printing Harold Hall’s Grinding Rest
Home Forums Workshop Techniques 3D printing Harold Hall’s Grinding Rest
  • #120969
    Paul tindall
      @paultindall15814
      I see there is an article on a Reprap 3D printer in next month's MEW. I too recently built one – the smaller Huxley version.
      As a relative beginner to Model Engineering, I've been working my way through Harold Hall's milling course book, which inevitably means I'm building the advanced grinding rest.
      I saw some queries in a post recently on how it all goes together, which I wasn't too clear on myself.
      So, I decided to try 3d printing the parts, before completing all of the metal bits, to see how it works. This involved drawing the parts from the book in a CAD package (the very good OpenSCAD – see http://www.openscad.org/), and printing them. The photos show various parts: Top Slide(8), Slide Swivel(9), Lower Slide(4) and Table. The other photo show the table next to the real one and finally a partial assembly with a mixture of plastic and metal parts.
      Was it worth it, well yes – I've learn the CAD programme and the printing process. I know what works and what doesn't. Don't expect precision, but it has its uses. I've also printed:
      Its a very useful addition to the workshop and well worth having a play.img_0090.jpgimg_0091.jpg
      Edited By JasonB on 30/05/2013 09:51:32
      Paul tindall
        @paultindall15814
        #120978
        John Haine
          @johnhaine32865
          That's brilliant Paul! The metal bits look well made as well.
          John.
          #120984
          MICHAEL WILLIAMS
            @michaelwilliams41215
            Am I the last person on the planet that can read a simple drawing and then just go and make the parts ????
            #120999
              No your not the only one.
              Does seem a bit of a waste of printing as if its been drawn in a 3D programme you could have assembled the parts there and by putting your mouse on the handwheels turned the feed screws or undone the levers and seen how it works.
              J
              #121008
              Trevorh
                @trevorh
                My son has just purchased one of these 3D printers and was looking for a project for it, I think I now have the perfect use for it
                That does look good, what kind of precision did you get on the individual components?
                how long did it take to print off
                cheers
                #121010
                Brian
                  @brian
                  This thread would be great if I could read it. The same old problem text and attachments being hidden by the addverts. Stand by for more comments like this.
                  #121012
                    Is that any better now Brian, I have resizes the images. Although they looked fine on my computer anyway.
                    Back on topic. Treveor I don't think the idea is to actually use the plastic parts and I'm not sure how well they would stand upto a stream of sparks and grinding dust.
                    J
                    #121014
                    Andyf
                      @andyf
                      My compatibility button usually does the trick, Jason, but not when images are side by side, as here.
                      A work-around is to highlight the text of the message, copy it, and paste it into the Reply box below, without actually sending it, of course.
                      Andy
                      #121016
                      Paul tindall
                        @paultindall15814
                        Ok, I did this exercise more to learn about 3D printing than use the parts – they certainly would not be used in a real grinding rig. Critical to making the process usable is the CAD process.
                        Having drawn components in OpenSCAD I an now confident that I can quickly knock up (3D priniting is about rapid prototyping and making objects which are difficult/impossible to make another way). It also make little mess as it is an additive process – no swarf!
                        I'm achieving about 0.1-0.,2mm accuracy – not stunning but ok. I am still learning how to tweak the machine. Print time varies and depends on the slicing depth (how thin each layer is), the size and the fill ratio. The parts shown took 4 hours to print in total. A long time but you can just leave it to get on with it.
                        I am finding numerous uses for it in the workshop, just as I did when i got my lathe and mill – I use it for all sorts of things. As mentioned in the 1st post (but obsurred by the photos) I have to date made:
                        • Vice Jaws
                        • Lathe Indexer for my Hobbymat
                        • Change gears for the above
                        • Drill/Milling cutter holders
                        • Cable clips – various
                        • Tool Hooks – various
                        • Angle jigs
                        In addition, other small items like trim parts for the wife's car.
                        #121019
                        Trevorh
                          @trevorh
                          Hi Jason, Paul, I think you mis understood my comment, it wasn't to use the parts in place of but as an actual template.
                          A drawing even in 3D can only give a limited amount of "Feel" for the part you are designing or wanting to make, But to actually see it and "Play" with it often will give a better insight as to its design and what might need tweeking before committing to steel
                          I was also wondering as to what the melt temperatures are and are they adjustable as i work in the Extrusion industry all be it on a lot larger machines and as such also have access to all of the various resins/ploymers
                          cheers
                          #121020
                          Douglas Johnston
                            @douglasjohnston98463
                            Hello Paul,
                            I have been fascinated with the idea of 3D printers for ages but have never done anything about it. Roughly how much do they cost to build and are the plastic consumables expensive to buy?
                            Doug
                            #121021
                            Brian
                              @brian
                              Had to press the compatibility button to reveal all, you waved your wand, thanks Jason.
                              Brian
                              #121025
                              Tony Jeffree
                                @tonyjeffree56510
                                Paul –
                                Not that I needed much persuasion, but seeing what you have produced has convinced me that I need one of these! Even if you plan to make the parts by hand, in metal, for the finished article, the ability to prototype relatively quickly in plastic to see how the design fits together looks very useful indeed – a great addition to any workshop IMHO.
                                Tony
                                #121029
                                Paul tindall
                                  @paultindall15814
                                  Hi,
                                  answering a few questions:
                                  Cost – well you can buy a kit from http://www.reprappro.com (no connection etc). I reckon that a model engineer can make one for £200 – 250, depending on what's in the scrap bin. Motors, and electronics are the most expensive, although the steppers are much smaller than those on a CNC mill. You can also buy 'comercial' hobby machines for £1-2K.
                                  Plastics I use are various colours of PLA – 1.75mm filiament. Lots of suppliers on Amazon, ebay or google arround. Typically 20 to 30+ quid for a Kg. Quality varies. It can also print with ABS (as used in Lego bricks) and some have tried nylon..
                                  Extrusion temps vary with plastic – PLA about 175C, ABS 220C although it requires experimentation. Its easy to vary the temps with the Open Source S/W which I use.
                                  Paul
                                  #121031
                                  Trevor Wright
                                    @trevorwright62541
                                    Paul,
                                    You say you are getting a 0.1-0.2mm accuracy – do you account for shrinkage in your cad design? I ask this because mine will shrink around 0.5-0.7mm after printing.
                                    I am using Faberdashery filament, the best, but reducing the print temperature only prevents extrusion, so I am intrigued as the to bed and hot end temperatures you are using. Your prints in the photos look much better quality than mine.
                                    My machine is a Huxley rep-rap.
                                    Trevor
                                    Posted at the same time lol.
                                    Edited By Trevor Wright on 30/05/2013 12:49:21
                                    #121032
                                    Trevor Wright
                                      @trevorwright62541
                                      Building the Huxley is not as straightforward as it first appears, it took me 2 months before I was printing.
                                      Mechanical build was ok but the wiring was a nightmare, due to bad instructions and photographs showing similar machines wired in opposite directions…….
                                      The software would have had me pulling my hair out (if I had any)…..you need to read up on python software to get anywhere….Once installed and working you go to a front screen that works everything with a click………it's getting it installed that is the killer.
                                      Trevor
                                      Edited By Trevor Wright on 30/05/2013 12:57:46
                                      #121033
                                      Paul tindall
                                        @paultindall15814
                                        @Trevor,
                                        the temps I gave are text book temperatures. For my machine I extrude PLA at 202 deg C and heat the bed to 85 dec C. I also use PVA on the bed (20:1 water/PVA) as I had warpage issues with cheaper plastic.
                                        Re: shrinkage, well I guess I should have allowed for it depending on size etc. In practice, I printed a calibration cube (Thingiverse.com) and adjusted x/y parameters accrodingly. My biggest problem is surface finish. I've improved it by removing as much backlash from the axes – keeping the belts tight, lubricating the moving surfaces regularly. This helps, but for me the biggest effect was to remove slop in the table (supported by 3 spring-loaded M3 screws. I was getting quite a bit of movement here. Temporarily, I've put a spring on one of the mounts, which takes up the slop (the forces on the bed are pretty small so this seems to work).
                                        Building the Huxley took about 2 weeks of evenings. Mechanical instructions were pretty good. Wiring, I agree the instructions lacked a bit. I do electronics an s/w for a living so I managed to work it out.
                                        S/W installation was fine for me. I quickly switched to Repetier (www.repetier.com) for the control software.
                                        #121035
                                        GaryM
                                          @garym
                                          While not wishing to resurrect the debate about hidden text and page displays, I was having trouble with this page and found that if I turn compatibility view off the page displays perfectly. If I then turn it on again text is hidden. Weird? I'm forced to use IE at work but detest it like the plague.
                                          Gary
                                          #121041
                                          Russell Eberhardt
                                            @russelleberhardt48058
                                            Posted by Trevor Wright on 30/05/2013 12:46:34:
                                            Surely the shrinkage depends on the size of the part. I used to be involved with plastic mouldings and we allowed 0.5 % for shrinkage after it came out of the mould.
                                            Russell.
                                            #121118
                                            Trevor Wright
                                              @trevorwright62541
                                              Paul,
                                              temperatures are spot on to my optimum, I ditched the m3 screws and replaced them with studding, locking with nylocs to the cradle, springs then another nyloc to adjust the height.
                                              Wish I was a software engineer – understanding the jargon was the hardest part.
                                              Never thought of calibrating the X/Y axes, will give me something to do tonight.
                                              Don't use PVA, but clean with acetone instead. That sticks – I have to design a screwdriver pocket on each component to jemmy them off after they cool to below 35°C
                                              Trevor
                                              #121121
                                                Most impressed. This is the first time I have seen anything useful done in amateur printing. I couldn't think of anything I could use it for previously. It woud be interesting to see some of the other things you have made. Are the hobbymat gears strong enough?
                                                #121122
                                                Speedy Builder5
                                                  @speedybuilder5
                                                  I reccon the process could be good for making one off drilling jigs (bush the holes), milling wedges / fixtures etc. I saw on TV also, that they are developing metal deposition and ceramics, such that it could be possible to print electronic components.
                                                  #121124
                                                    I saw a godd video the other day of printing sand, saves having to allow any draft angle on patterns or using loose pieces as there is no pattern to pull from the sand, just print and pour. Prints the feeders, runners and cores as well.
                                                    #121130
                                                    Paul tindall
                                                      @paultindall15814
                                                      Re: Shrinkage/calibration, the X/Y axes are scaled according to a calibration scaling factor held in the firmware. By printing a 25mm calibration cube, you can see how long/short you are in each axis and scale accordingly. This should take out the shrinkage ratio, provided it is constant across length. I suspect it is approximately so.
                                                      Re: Hobbymat change gears – I use them for indexing – so strength not an issue. I am going to print the small 30T gear – which takes a hammering, and use it for power feed, so will let you know how strong it is. When indexing, I tend to scribble on the gears with marker pen, so I don't lose track. Using printed gears keeps my original set pristine.
                                                      However, I am considering not using gears at all, but use depthed holes at the angles I require, and use simple rod to lock them. I can also just print the exact number I need, eg 18 holes, and print numbers on the face so I don't forget where I am.
                                                      Re: other stuff printed – I will add to my album when I get time ….
