Hi folks,
A recent project with my grandson resulted in an attempt to make a UNF 3/8 24tpi tap out of silver steel. Lots of things went wrong but we did eventually manage to cut a thread in a piece of aluminium. This is what we did, along with what we know we did wrong, but I’d like to ask, for the future that is, for any other thoughts.
I should point out that one of the reasons for this project was to let the grandson do as much as possible, and to see the rest.
First we took a piece of half-inch silver steel and turned it down to 3/8ths. Unfortunately the only way that we seem to be able to get a smooth, and hence accurately measureable, surface is to rough turn first, then finish turn using high speed and slowest possible manual feed. So of course, the finished surface ended up slightly less than it should have been, and a repeat attempt the same. As it happens, the device that was intended to screw in was itself slightly less, so we continued.
Next we screwcut. In retrospect we should have produced the taper first, so that was yet another mistake. Anyway, I’ve never had much luck with trying to calculate depths of cut etc for screwcutting and so had to resort to using a nut as a test piece. So this is what we did, and produced a thread.
At this point we tapered the job. That was ok, we used 8° included as per Tubal Cain’s instructions.
Then we tried to create a cutting edge using a minidrill with a grinding disc in the chuck. We had looked at other similar sized taps and realized that we needed to produce an undercut under the cutting edge and so we tried to set the minidrill appropriately. We weren’t particularly successful and finished up using a file to try to improve matters. Thoughts on how to do this would be most appreciated. Also on how to produce, say, three cutting edges.
Having got this far we then hardened it. Ok we didn’t bother with the one hour per inch as per Tubal Cain and others, but neverthe less got it very hot and then quickly dunked it in cold water. This was followed by tempering to light straw, although here again I suspect we may have heated it too quick and possibly had some of it nearer brown.
We tried it out on a piece of aluminium, slowly increasing the drill size until we could get it to cut, which it did after a fashion. After cleaning up, we found that the original device it was meant for could actually be screwed in, albeit tightly, so in that respect it was more or less successful.
Grandson, by the way, was absolutely delighted with the result, even though it wasn’t perfect. To him, it was the act of screwcutting in the lathe and then hardening and tempering the silver steel, none of which he has ever seen before.
So, thoughts please.
Peter G. Shaw
