I think one of the biggest downsides to converting the type of mills you and John link to is the existing head.
Firstly you have a quill that is not needed and will be a source of play, noise and reduce rigidity
Spindle bearings will not be as good, for example my X3 manual mill has one taper and one plain bearing costing about £20 to replace. My KX3 has a pair of matched high quality taper roller bearings that I'm told could be in the region of £250
Then you have the lack of speed as most only go to 2-2500rpm which will increase run time using small cutters which are what these machines are best suited to
There are ones on the web that have had the whole head removed and replaced with spindle motors which gets round the problem but you are going to have to pay for it. At least the basic machine should be able to make the parts needed for the head swap
Edited By JasonB on 20/01/2022 10:05:09
