I'm converting my Harrison vertical mill to CNC, triggered by the original lead nut having about 0.050 of back lash and needing yet another VFD if I wanted to use the power feed. I've replaced the X axis lead screw and gear box with a 2005 ball screw and NEMA 34 stepper. I used standard fBK15 and BF15 fixed and floating bearing blocks (that I made myself as no-one had the size I needed) and a pre-machined ball screw. All was well. I'm now in the process of doing the Y axis. I can't use the standard bearing blocks as I'm very restricted for bearing height (shaft centre to top surface of knee), so rather than use angular contact bearings I've used a pair 51102 thrust bearings, mounted into seats in a 35mm thick block of steel that mounts to the front of the knee. This is a very similar setup to the original design but the larger block allows me to mount a plate/box that will house the timing belt/pulleys and serve as a mount for the stepper. To take the radial load from the timing belt I've used a single 6002 ball bearing on the same 15mm journal that the trust bearing are on. The problem I have is when I bolt the 10mm thick aluminium plate to the front of the bearing block (this plate has the seat for the 6002 bearing) the spindle/bearing assembly acquires a considerable tight spot. When I remove the 10mm plate from the front and reassemble everything with a dti, the 6002 bearing is out of concentricity by almost 0.25mm. all 3 bearings are on the same 15mm journal and it is spot on size (15.00mm). the only plausible explaination I can think of is that the thrust bearings are duff, or one of them is. They are supposed to be 9mm thick, and one is spot on 8.99, but the other is 8.89 which is quite some error for a bearing surely? The other explaination, would be my bearing seats in the 35mm block aren't concentric, but surely this would just serve to give me a spindle that isn't perpendicular and bearings that aren't loaded evenily, it wouldn't cause 0.25mm of concentric error? I'm pretty sure the bearing seats are within 0.02mm or less anyway, so I can't see how that could cause the massive error I'm seeing.
Thoughts anyone?
I'm going to order a pair of FAG of SKF thrust bearing (these were Dunlop) and see if that fixes things.
The spindle in the first photo is the original lead screw, the other photos are my 1605 ball screw with an entension sleaved and bonded onto it to give the additional diameter i need to mount the thrust bearings. I've spent today remaking the spindle/extension thinking that was the problem, which it wasn't (and couldn't have been, 4hrs wasted).
This video shows the issue. Here the dti is on the 12mm part of the shaft that carries the taper bush for the timing pulley, but the same thing happens with the bearing that is on the 15mm journal.
https://www.youtube.com/watch?v=HC2h8gP6kkQ
![Y axis thrust bearing block 2 Y axis thrust bearing block 2](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
![Y axis thrust bearing block 4 Y axis thrust bearing block 4](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
![photo from mark davison(2).jpg photo from mark davison(2).jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
![Y Axis ball nut and carrier 2 Y Axis ball nut and carrier 2](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
![20200627_160709.jpg 20200627_160709.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Edited By Mark Davison 1 on 27/06/2020 17:16:11
Edited By Mark Davison 1 on 27/06/2020 17:18:29
