Hi, Andrew.
I bought the CW8060 60 volt drivers and the 60 volt power supply from CNC4You.uk.
The Ethernet Smooth Stepper I got from from Amadeal.
The Break-out Board I got from Machdrives in Australia. This is a very good board with a very stable 0 – 10 volt output to control a Siemens Micromaster 6SE Variable Frequency Drive which drives the original GEC 3 phase motor. The spindle pulses come from the original Orac and if the Mach3 settings are correct it is excellent.
I have cut a 30mm diameter x 5mm pitch (not 6mm as I said before) trapezoidal thread at 200 rpm and though it is scary to look at everything worked fine for the 150mm long shaft.
