Curve Cut Problem
Curve Cut Problem
  • #433323
    nigel jones 5
      @nigeljones5
      Hi. Im using Curve Cut to process a 2d drill sequence. Problem is no matter what inputs I use I cant get away from "will result in more than 20 passes". Its a simple drill, retract move and repeat. Any idea what im doing wrong?
      nigel jones 5
        @nigeljones5
        #433761
        Nick Hulme
          @nickhulme30114
          If you add what CAD/CAM/Controller you are using people with relevant experience will be able to comment.
          #433775
            I thought Curve Cut was the CAM
